Shocks and articulation
- Mole
This is somthing iv been thinking about but cant quite get my small amount of grey matter round. I have a 2" lift spring and shocks and with the anti roll bar disconnected it dose seem to keep the wheels on the ground quite well now my question is if I where to fit a 3" shocks but keep the springs at 2" would I gain any more articulation or with it twist mounts or just pop the springs out.
- Thank you received: 2005
- Mole
And spring clamps are available to hold spring to axle
I only run 2" springs and shocks.......But i have +3" radius arms all round......works very well in my opinion
I'm not disagreeing with most of your advice, but a 3" lift is not at all the same thing as a +3" longer shock.Lambert wrote: Doing that will increase your risk of bottoming out a damper on full compression which is as bad as it sounds. It also increases your risk of disconnecting a spring which is also as bad as it sounds. Then you're also going to need longer brake lines or you're going to have the entire axle droop being limited by the flexible pipe again as bad as it sounds. Mixing and matching different springs and dampers is something best done by professionals who know what they are doing and how to mitigate risks. As a layman I would suggest sticking with a proprietary solution like a full 3 inch lift kit with all the necessary matching parts.
I know less about Jimny suspension than I do about Land Rovers, however the principles and physics will be the same.Mole wrote: Morning.
If for example you removed your shocks completely and the springs, you could then see how far up the axle will travel and how far down. If this is less than the distance your shock allows, then a longer shock would not offer any benefits. If it is greater, then either the spring and/or the shock are limiting travel. I do not know if the Jimny deliberately uses the shock to limit the travel (some setups do), but not all.
Removing the shocks and springs would also allow you to see what does limit travel. Brake lines can be a point of limit, but not one that would physically stop an axle dropping, just one that would break should you let the axle drop that far. Bushes, joints and the design of the suspension are the most likely causes however.
To match a shock with your axle travel, you need one to extend far enough, but also to have a closed length that is shorter than the distance of the fully compressed axle. Else you will bottom out the shock, i.e. the shock will not go short enough. In the Land Rover we generally move the upper shock mount up, to allow a bigger shock with a longer stroke to fit, thus more droop (down travel) and the ability to close to the full compression (up travel). Sometimes you can limit the up travel by fitting extended bump stops, but to my mind this is just limiting your travel.
Once you have the shock length/stroke dialled in, you need a spring to match. Too short a spring and it'll fall out, too long and you'll get coil binding before full compression. Too hard and it simply won't compress. In the Land Rover world we also use retained springs, i.e. the spring attached top and bottom. This stops them falling out, but if they are too short they will get stretched at full droop, which isn't good and they will reduce the downward force if being stretched. We also sometimes use dislocating springs, which can fall out, then reseat themselves. These have pros and cons though.
Basically for a good off road setup you want to match the shocks and springs together with the available travel you have. In most 4x4 circles it is often all too easy to lift a vehicle for ground clearance and bigger wheels. But actually reduce the off road effectiveness of the suspension.
