Diff ratios
- Mole
21 Nov 2019 20:21 #215843
by Mole
Diff ratios was created by Mole
Evening.
I know this has been covered so dont want to flog a dead horse but I got a little lost while reading the posts. From what I gather jimny diff ratios vary through the years what years do they change, I have a 2002 and wanted to know if older models have lower geared diffs ie. Better for off road/bigger tires rather than changing the T-box
- X8GGY
21 Nov 2019 20:36 #215844
Replied by X8GGY on topic Diff ratios
From the Wiki link at the top of the page -
www.bigjimny.com/mediawiki3/index.php?ti...ssion_gearing_ratios
So for instance, in my old X-reg buggy build I have swapped the diffs from 3.9:1 to later (VVT) diffs which are 4.3:1 to correct the gearing for 30" tyres
In my VVT I have swapped the transfer box to an earlier stick model AND the diifs to correct the gearing for 29" tyres.
- Mole
21 Nov 2019 20:58 #215846
by Mole
Replied by Mole on topic Diff ratios
Lovely thank you. I would like to run 30s so if mine is the vvt I should be able too correct? And on that note how to I tell if mine is the vvt. Apologies for the daft questions
- X8GGY
21 Nov 2019 21:25 - 21 Nov 2019 21:27 #215847
If yours is a 2002 then it will have the 'older' 3.9:1 diffs in, if you were to fit 4.3:1 later VVT diffs you'd be able to fit 30" tyres and have the same gearing as stock...
4.3 / 3.9 = 1.10 ......... new diff 'final drive' / old diff
30" / 27" = 1.11 ......... new tyre diameter / old tyre diameter
That's what I've done to correct the gearing on my buggy build...
Last edit: 21 Nov 2019 21:27 by X8GGY.
- Mole
21 Nov 2019 21:38 #215848
by Mole
Fantastic thank you
Time to create page: 0.094 seconds
