Transfer box Auto v manual
- Pommy bastard
20 Nov 2019 00:53 #215787
by Pommy bastard
Transfer box Auto v manual was created by Pommy bastard
I’ve got big tires on the Jimny 31 10.5 15 this has increased the speed in low range to much. Someone suggested that the transfer box in an Auto was lower geared is this correct ? Big tires required for soft wet ground it’s peaty soils and once you break the surface your gone but have found that when climbing hills that the Jimny is just a bit to quick.
- Thank you received: 2004
20 Nov 2019 05:04 #215788
Replied by Lambert on topic Transfer box Auto v manual
Welcome to the forum. I have sent you a private message. As to the transfer box yes and no it depends on if you have a earlier lever operated box or a newer push button one.
- Pommy bastard
20 Nov 2019 10:15 #215795
by Pommy bastard
Replied by Pommy bastard on topic Transfer box Auto v manual
thanks but have had no private message as yet and mines manually operated on the stick
20 Nov 2019 10:39 #215796
Ah right. If you have a manual transfer box it is already the lower 1.3/2.2 high low. In the Jimny information section at the top of the page there's a wiki with contains all the available transmission ratios so as to mix and match diffs and boxes. Also have a look at a site called grimjeeper it has a gearing calculator.
- kc
16 Oct 2020 16:05 #229175
by kc
Replied by kc on topic Transfer box Auto v manual
Hi there I have a 2005 electrical transfer box and am I able to put a manual in with out having to modify the propshafts and will it affect hi ratio be affected
16 Oct 2020 16:35 #229179
Hi yes it will fit there's even a cutout in the transmission tunnel for the lever. It will however significantly affect the gearing. The electric one is 1to1 the lever type is 1.3 to 1 so in an otherwise standard vehicle will seriously reduce in gear speed to the point of revving the nuts off it just to keep up with normal traffic. However if you want bigger tyres then it's going to help greatly.
Time to create page: 0.738 seconds
