M13a gearbox wanted
- Rattray125
18 Nov 2019 17:15 #215740
by Rattray125
M13a gearbox wanted was created by Rattray125
Hi does anyone have a m13a gearbox for sale. Im in the west midlands so closer the better.
Also will any other gear boxes fit on apart from.the m13a ? Thanks alex
18 Nov 2019 17:35 #215742
Replied by Riccy on topic M13a gearbox wanted
What year Jimny?
By M13a I assume you have a VVT jimny 2005 on. This means you have a R72 gearbox.
To convert it to the earlier (tougher) box you need my guide here:
www.bigjimny.com/index.php/forum/7-jimny...7me-conversion-guide
Note - you will need to source and swap t-box and diffs to the earlier versions as well.
A lot of work and parts needed there, the alternative is a rebuild of the r72 you have with newer sealed bearings (£700-1000 region), or a used R72 box from a 2009 or newer car (which have the sealed bearings and are reliable). Similar money probably. Also its worth getting a new clutch fitted when its in bits
- Rattray125
18 Nov 2019 18:15 #215745
by Rattray125
Replied by Rattray125 on topic M13a gearbox wanted
Its a 51plate on the logbook it juat says its a 1.6 16v dont say vvt
- Rattray125
18 Nov 2019 18:16 #215746
by Rattray125
Would a jb33 fit found one on ebay the chaps selling for 60pound
19 Nov 2019 07:29 #215759
Replied by Riccy on topic Re:M13a gearbox wanted
Right so you shouldn’t have the vvt at that year and it sounds like someone has put a bigger engine in.
You need to find out if you have a g series or an m series engine and get a box to match. G series ha e 16 valve embossed on the cam belt cover at front, m series have dohc on the top of the engine.
- Rattray125
19 Nov 2019 12:05 #215767
by Rattray125
Replied by Rattray125 on topic Re:M13a gearbox wanted
Thanks for the reply ill have a look under the bonnet later an look at the cambelt cover. But on the logbook it says m13a
Time to create page: 0.125 seconds
