Squealing
- Craigyh1990
07 Nov 2019 20:24 #215458
by Craigyh1990
Squealing was created by Craigyh1990
Hi I’m new to Jimnys I’ve always had this very little squeak on idle and when I touch the clutch very gently it completely goes away guessing it a clutch bearing no issues with the drive at and does not do it when driving ???? Also it’s been parked up as I been working away since September started it up last night and getting a squeak rev it goes away and comes back been told it my fan belt where been sat after driving it for abit it wasn’t as bad then went away for a while hope some one can help me out Thankyou
07 Nov 2019 20:46 #215460
Replied by Daniel30 on topic Squealing
What are the belts like condition wise? Any cracks? Might just be worth changing if you can't tell where the squeak is actually coming from, any changes in the squeak if you turn lights on full and heating etc?
- Craigyh1990
07 Nov 2019 21:12 #215461
by Craigyh1990
Replied by Craigyh1990 on topic Squealing
Just same and no different with lights or air con on etc that I have noticed anyway so il do as you said and go with the belt change there’s few marks on the belts no major cracks or anything tho it’s not Made the noise after a good drive today but don’t want them snapping or anything if this is a sighn there on there way out Thankyou for the reply
07 Nov 2019 23:09 #215462
by kirkynut
It could be the power steering belt tensioner bearing slightly dry. I'd not worry about it unless it really starts to make a noise.
Time to create page: 0.091 seconds
