jimney 2017 boging down when blipping throttle
- barnsley john
23 Oct 2019 19:43 #215089
by barnsley john
jimney 2017 boging down when blipping throttle was created by barnsley john
if you just tickle the throttle or a slight blip on tickover the engine bogs down or sometimes stalles
car runs perfect apart from that 9000 on clock any help i have had a good look round engine twiddled every thing but cant see anything thanks john
- Thank you received: 2004
24 Oct 2019 04:21 #215097
Replied by Lambert on topic jimney 2017 boging down when blipping throttle
This isn't a guaranteed solution but if it is or has been doing a lot of very short trips especially with cheap supermarket fuel there's a possibility that it has started to build a layer of varnish inside the intake tract. This could respond to a hard thrash down the motorway on some nice clean reputable fuel aka an Italian tune up. Alternatively you can pay to have it terracleaned other similar services are available. The other option is that you have a fault with the electrical system but that is potentially going to be a pig to find if it's not leaving a code. Good luck.
24 Oct 2019 06:52 #215102
by Scimike
Replied by Scimike on topic jimney 2017 boging down when blipping throttle
It's possible (amongst other things) that the IAC valve is dirty or sticking. Not removed one for cleaning myself from the Jimny, but it's a common problem (in the world of cars). The Italian tune up ^^^^ can work well on a short run vehicle, so worth a try (and more fun) than cleaning the IAC. After these it's gets harder to find the issue.
Goog luck.
Mike
Goog luck.
Mike
The following user(s) said Thank You: barnsley john
25 Oct 2019 10:01 #215138
by kirkynut
Replied by kirkynut on topic jimney 2017 boging down when blipping throttle
The lack of use and symptoms lead me to think of the Idle Control Valve sticking.
Do you use it seldomly also?
If you do use it seldomly, try using it a little more often.
Note the comment about using good quality fuel from one of the big manufacturers rather than supermarkets. Yes the raw petrol comes from the same refinery before the neigh sayers start, but the additives are important and the big manufacturers have good quality ones.
Time to create page: 0.106 seconds
