Re:GEN 4 Wobble
- Tex
08 Oct 2019 09:33 #214461
by Tex
Replied by Tex on topic GEN 4 Wobble
No wobble on mine either. Nearly 4000km done.
09 Oct 2019 09:58 #214505
by Micheal
Replied by Micheal on topic GEN 4 Wobble
Morning Folks, had a look at the obvious points this morning, nothing I could see that would account for the wobble. We bought this second hand with 1000 miles and the previous owner had changed the wheels from 195/80R 15 to 215/75 R15 and fitted Grabber AT tyres. Could this be the reason?
Thanks
Thanks
09 Oct 2019 11:03 - 09 Oct 2019 11:04 #214509
Replied by mlines on topic Re:GEN 4 Wobble
Are they fitted and balanced correctly? In particular look where the yellow and red dots are on the tyre in relation to the rim.
If there is a yellow spot this should be next to the valve.
If there is a red dot (and a yellow one) the red dot should align with the dimple or dot on the rim and the yellow dot ignored
And definitely check the pressures
Last edit: 09 Oct 2019 11:04 by mlines.
10 Oct 2019 22:26 #214587
by Bob1050
Replied by Bob1050 on topic Re:GEN 4 Wobble
Have passed 10k miles (not kms) and zero sign of any death wobble on mine. As others have indicated - it may be down to other issues such as tyres/wheels.Certainly shouldn't be down to wear and tear on the axle/steering components at such a low mileage.
13 Oct 2019 07:29 #214685
by kirkynut
Replied by kirkynut on topic Re:GEN 4 Wobble
I reckon it is wheel balancing.
13 Oct 2019 09:43 #214691
by Micheal
Replied by Micheal on topic Re:GEN 4 Wobble
Thanks all, the tyres were a bit low on pressure and that seems to have improved it a bit (I might just be getting used to it!) but I still detect a wobble esp around 40mph. I can't see anything obviously wrong, will take it in to have wheel balancing checked.
