Re:GEN 4 Wobble
- Grima
Will need to find a similar back street tyre fitter!
Anyone have views on the Suzuki supplied jack?
Thanks
- Thank you received: 1940
Lambert wrote: Not all tyre places have one or are inclined to use it if they do but there is an adapter for balancing machines that allows the wheels to be bolted on with the actual bolt holes instead of the cone through the centre bore. This is the only accurate way to balance the wheels on a Jimny though some of the alloys can be got close enough with the cones most can't and all should be bolted on. It takes longer to do obviously and so most places will try to avoid it but be insistent and even offer to cover the extra cost as it is worth it to have the wheels correctly balanced. Alternatively you can get balance beads which are loose inside the tyre and spread out under rotation to dynamically balance the wheel in real time.
a very big +1 for the balance beads.
Ive had issues with admittedly much larger tyres and balancing. The only way ive found that provides satisfactory results is the balance beads. They come in two flavours - plastic and ceramic. Ive tried both and must say that the ceramic ones are far better. They dont clump or wear the inside of the tyre, all while providing perfect wheel balance.
Thanks
