High RPM's
  • Dchab
09 Aug 2019 14:42 #211952 by Dchab
High RPM's was created by Dchab
I own a 1994 jimny from Japan and was wondering if anyone had any issues with high rpm's. I can only get it up to 80kph which is sitting at around 6500 rpm. It is a 3 speed auto but it it feels like it doesnt shift into 3rd. Ive taken it to a mechanic few times and they said that there was no issue. Is this high rpm at that speed normal for this?
09 Aug 2019 15:17 #211953 by Lambert
Replied by Lambert on topic High RPM's
Welcome to the forum. No it isn't normal. Have you changed the transmission fluid, it should be a clear red colour on the dio stick.
  • Dchab
20 Aug 2019 02:00 #212333 by Dchab
Replied by Dchab on topic High RPM's
So, figured it out. Ended up being the linkage for the shifter needed to be adjusted. It looked like it was in drive but actually it was in 2nd the whole time. One other thing though is when I hit an incline, it actually starts to slow down until I get to a level surface then it picks back up again. I'm guessing that might be normal and would probably have to shift into 2nd to get up a little faster.
Time to create page: 0.197 seconds
