Stalling problem please help!!!
  • Olliecarr25
06 Aug 2019 09:24 #211874 by Olliecarr25
Stalling problem please help!!! was created by Olliecarr25
Hi there I have a 2002 Jimny that once hot starts staling / jolting and the Rev gage goes all over the place then it cuts out then after a few minutes it starts up again fine I have changed the fuel pump and fuel filter, HT leads, spark plugs, cam angle sensor but with no luck was wondering if anyone has had the same problem or knows what it might be thanks in advance.
06 Aug 2019 12:36 #211878 by Keithy
Crank sensor?
The following user(s) said Thank You: Olliecarr25
06 Aug 2019 15:24 #211883 by jackonlyjack
+1 on crank sensor
Get a water spray bottle filled with cold water
when it starts playing up give the sensor a good spraying to cool it down
if it starts to run good again if only for a short while try a new or second hand one
it's under the alternator
06 Aug 2019 20:44 #211895 by kirkynut
Before you throw any more parts at it in the hope of fixing it, stick a code reader on it if it is a twin cam. They're cheap enough now for a basic one.
If it's a single cam I think there is a code reader available but I've never followed what it is as I don't have one. Single cam engines were in the soft tops only for 2002.
  • Olliecarr25
07 Aug 2019 06:07 #211901 by Olliecarr25
Replied by Olliecarr25 on topic Stalling problem please help!!!
Thank you, I have taken it to a garage and they plugged it in and couldn’t find anything wrong with it but I do know it’s a M13A engine.
07 Aug 2019 20:19 #211927 by jackonlyjack
Not sure if faulty crank sensors throws out a code
Sure i read somewhere they don't
