Catalytic converter
  • StergiosJimny
20 Jul 2019 10:24 #211310 by StergiosJimny
Catalytic converter was created by StergiosJimny
Hey guys. My catalytic converter is dead. I have the m13a vvt model. Now what? The echaust is stock. What about a universanl catalytic converter with 200 or 300 cells? Will I see any difference?
20 Jul 2019 10:28 #211311 by kirkynut
Replied by kirkynut on topic Catalytic converter
Get a garage to fit an aftermarket Jimny one. They're not that expensive as they don't all contain precious metals now.
I wouldn't muck about with it myself as bolts will be proper seized and need heat to undo no doubt.
  • StergiosJimny
20 Jul 2019 10:39 #211315 by StergiosJimny
Replied by StergiosJimny on topic Catalytic converter
Thank you Kirkynut. Should I look to ebay? Because I cant find something for jimny here in Greece. I can find only a universal one.
Is it metallic or ceramic? What about the cells?
20 Jul 2019 18:12 #211328 by Scimike
Replied by Scimike on topic Catalytic converter
I would go for one listed to fit your Jimny sold on eBay if you can't get one locally. I had a local exhaust place fit mine and it looks exactly the same as those I have seen on eBay, suspect they all come from the same place. Don't know the answer to the makeup of the CAT, but the aftermarket one I had fitted passed the emissions test no problem.
22 Jul 2019 07:38 #211377 by kirkynut
I don't know what your garages are like in Greece. If they're able to supply and fit then I'd just let them do it all. If it goes wrong it's their problem.
My cheap one must have been on it for 8 years without issue.
Time to create page: 0.099 seconds
