4wd problems
- Markmills96
27 Jun 2019 21:18 #210389
by Markmills96
4wd problems was created by Markmills96
Hi guys, having an issue with the 4wd. when selecting 4wd it doesn't engage straight away, you have to really wrestle with it for about 5 minutes for it to finally engage which I'm presuming is a problem with the vacuum lines. The real issue is when I'm driving along normally on the road, to say work and back, it'll start making a loud grinding kinda noise which the only way to shut it up is by slowing down on the side of the road. To me it's like the front wheels are trying to engage without me selecting it. Anyone know what this could be? Cheers
- Thank you received: 2004
28 Jun 2019 06:13 #210394
Replied by Lambert on topic 4wd problems
I think you have hit the nail on the head with vacuum hubs being at fault. You can either modify them into the permanent engaged position and rely on the transfer box alone for 4x4 shifting or you can convert to manual hubs. Chasing and fixing the vacuum is a painful process that potentially is just as expensive as the manual conversion.
01 Jul 2019 18:56 - 01 Jul 2019 18:58 #210494
by Bosanek
Replied by Bosanek on topic Re:4wd problems
The repair of the vacuum system has got more infamy than it really deserves. I have already repaired four Jimnys with vacuum system issues and only my own was a major hassle to diagnose (faulty wheel bearing without any symptoms).
Yes, the repair of the vacuum system can be a nightmare. But it can also be straightforward and simple, depending on what is wrong with it. I think that the wiki contains a lot of useful guidance to aid toward the simple side.
Sent from my SM-G930F using Tapatalk
Last edit: 01 Jul 2019 18:58 by Bosanek.
Time to create page: 0.079 seconds
