Identifying Lift
- Blackout
25 Jun 2019 17:47 #210307
by Blackout
Identifying Lift was created by Blackout
Hi guys I am thinking about replacing shocks on my jimny they look battered and the rear lower bush has gone on one.
The guy I bought it off said “2” body and 2” suspension “
The shocks have no identifiers on them. Is there an easy way to work it out or where to measure from? I’m running 235/75/15 tyres. It looks high, got a pic next to a standard (I think) and it looks a load higher. I’m not convinced it is 2” suspension but due to liking the height I don’t want to order and fit a 2” and discover it was 3 or 4
Any ideas / anyone measured theirs with a 2 + 2?
- X8GGY
25 Jun 2019 19:25 #210311
Replied by X8GGY on topic Identifying Lift
- Blackout
25 Jun 2019 20:48 #210313
by Blackout
Replied by Blackout on topic Identifying Lift
Awesome cheers Dave, will get tape measure out tomorrow !
26 Jun 2019 09:55 #210314
by Scimike
Replied by Scimike on topic Identifying Lift
In addition to the above if you can remove one of the shocks and measure it's fully compressed and extended dimensions you could get the supplier to check the ones being sent match this as a minimum. If you can get a smaller shock with a longer stroke it's the off road Holly Grail
- Thank you received: 2004
26 Jun 2019 10:29 #210315
Replied by Lambert on topic Identifying Lift
Any chance you can post a picture of the damper. Someone is bound to recognize it as there's only a limited number of aftermarket dampers that are usually used on Jimny?
- Blackout
26 Jun 2019 17:20 #210328
by Blackout
Guys thank you all for the input. I have attached pics and it seems to be measuring higher than Daves so not sure if it is 2” at all now
Time to create page: 0.113 seconds
