HELP Bent Front Axle
  • Scholtzey
29 May 2019 09:05 - 29 May 2019 09:07 #209164 by Scholtzey
HELP Bent Front Axle was created by Scholtzey
Hi , I need of some Help and advise please.
My Suzuki Jimny front axle is bent . 2017
Can It be repaired or must it be replaced?
Any for sale?
Milton Keynes
Thanks
Last edit: 29 May 2019 09:07 by Scholtzey.
29 May 2019 09:16 #209165 by sniper
Replied by sniper on topic HELP Bent Front Axle
You can repair most anything but it will have to come off the car, if you're taking it off, it would be very quick to fit a replacement secondhand axle complete.
Cost wise is a guess for repair but you won't have any surprises with a good replacement unit and you can service it on a bench before you fit it.
James Priestley ( j999pre on the forum) should be able to help with supply, he might even build one with new bearings if you ask him nice......
sniper
  • Scholtzey
29 May 2019 09:49 #209168 by Scholtzey
Replied by Scholtzey on topic HELP Bent Front Axle
Hi Sniper , I would like to repair as car has only done 3k. Do you know how can do it?
29 May 2019 09:57 #209170 by Lambert
Replied by Lambert on topic HELP Bent Front Axle
It depends on how bent the axle is as to whether it is economical to repair. Even if it is repaired unless you brace it then it will fail again and even thereafter it'll always be a concern. How did you bend it?
  • Scholtzey
29 May 2019 09:58 - 29 May 2019 09:59 #209171 by Scholtzey
Crashed .
Last edit: 29 May 2019 09:59 by Scholtzey.
29 May 2019 10:02 #209172 by Lambert
Ah. Is the rest of the chassis and mount points straight, it's just if it has been hit hard enough to bend the axle there's a high chance of further damage.
Time to create page: 0.228 seconds
