Stone Chips and T-cut?
  • Andy2640
19 May 2019 06:45 #208307 by Andy2640
Stone chips and t-cut? was created by Andy2640
Washed the car yesterday, found a tiny chip on the paint (Argggh). Just wondering whats the best product to use to keep them in check?
Any recommendations would be appreciated.
Thanks.
19 May 2019 07:08 #208308 by Lambert
Replied by Lambert on topic Stone chips and t-cut?
On my last scooby I had all the leading surfaces covered with a heavy clear vinyl. That worked.
The following user(s) said Thank You: Andy2640
  • Andy2640
19 May 2019 07:32 #208310 by Andy2640
Replied by Andy2640 on topic Stone chips and t-cut?
Lambert wrote: On my last scooby I had all the leading surfaces covered with a heavy clear vinyl. That worked.
Mmmhhhh ..... Now there's an idea. Thanks my lord :-)
19 May 2019 09:44 - 19 May 2019 09:45 #208334 by Scimike
Replied by Scimike on topic Stone chips and t-cut?
Stone chips are an annoying fact of life.
Lamberts already got option 1 which is cover the paint surface with a protective cover of some sort.
Option 2 - get a touch up pen and keep on to of the chips, done correctly you can't see the repair.
Option 3 - do nothing and when it gets a mess or you want to sell get "chips away" in to repair the panel.
Option 4 - embrace the rugged look, fit a snorkel and leave it covered in mud.
The reality is probably a mix of all, but don't get hung up about them, it's going to happen if you drive and enjoy the vehicle..
Last edit: 19 May 2019 09:45 by Scimike.
  • Guy 2
19 May 2019 10:51 #208336 by Guy 2
Replied by Guy 2 on topic Stone chips and t-cut?
I agree. Have used Xpel Ultimate film on the front, bonnet and sides of my BM - and two years in it has proved very effective. It has an element of 'self-healing' as well. Takes a strike and then the tiny hole somehow fills-in as the vinyl is warmed in the sun, over a day or two (or you can speed the process up with a heat gun).
Not cheap though!
After about 5 years then I think you are into Scimike's 'mix' of different solutions.
22 May 2019 15:07 #208683 by Max Headroom
Replied by Max Headroom on topic Stone chips and t-cut?
Depending how deep they are you might try repairing the damage by polishing them out with Autoglym Super Resin Polish.
It is just a polish but gives a small amount of protection. AG SRP has the capability to 'fill' damage and a chip or scratch can almost disappear. You'll need to build it up though, it will take time and patience.
Once the appearance of any damage is reduced, follow up with a good quality wax such as Colinite 845 Insulator Wax -or any other quality wax that you like.
I like Colinite 845 as it gives a particularly good 'wet' shine especially to white or silver coloured paintwork which is difficult to make look shiny.
There are 'magic' scratch treatments out there - but I've never tried them. Other than that its old fashioned touch-up paint.
I like the idea of the Xpel film - prevention better than cure
Time to create page: 0.207 seconds
