Gearbox/Transfer Case/Diff Breathers - Ingredients
15 May 2019 17:36 #208054
by furo
Gearbox/Transfer Case/Diff Breathers - Ingredients was created by furo
Hi folks,
I'm looking to install breathers for my gearbox, transfer case and differentials but everywhere I look seems to have sold out of kits. Could someone please let me know exactly what I need and where best to get it from?
Many thanks
Many thanks
- Thank you received: 706
15 May 2019 22:04 #208064
Replied by jackonlyjack on topic Gearbox/Transfer Case/Diff Breathers - Ingredients
You need 1/8 bsp tapered tap
2 x 1/8 bsp to 6mm push fit elbows for axles
gear box R7ME two ways of doing it 8mm to 6mm reducer
push the 8mm part into the rubber sleeve that comes from G box
Or i used this way pulled the sleeve off the box and replaced it with some rubber tube from the vac hub system.
around 6" long pushed onto the G box stub used a hose spring clip from vac system
then pushed the 6mm pneumatic tube around 2" then another hose clip
pneumatic tube front axle up to manifold on bulk head,G box also up to manifold,rear axle up to manifold with a 6mm equal T piece
which goes to T box (i have SJ transfer box) so can not give any advice on standard T box fitment
Jack
Jack
16 May 2019 11:21 - 16 May 2019 11:25 #208109
by furo
Replied by furo on topic Gearbox/Transfer Case/Diff Breathers - Ingredients
Thank you very much Jack!
Where does the breather attach to the gearbox exactly?
Last edit: 16 May 2019 11:25 by furo.
16 May 2019 11:52 #208113
by ahtr
There's some pics on my thread from when I did gearbox breather. LINK
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
Replied by ahtr on topic Gearbox/Transfer Case/Diff Breathers - Ingredients
furo wrote: Thank you very much Jack!
16 May 2019 16:30 #208133
by furo
Thank you, that's very helpful! Great build thread btw.
The following user(s) said Thank You: ahtr
Time to create page: 0.099 seconds
