Under sealing
  • Cremator1
05 May 2019 10:46 - 05 May 2019 17:02 #207361 by Cremator1
Under sealing was created by Cremator1
Hi all Looking to underseal my jimny pressure washed all off this morning going to let fully dry but not sure if I need to treat the surface rust first or can I go straight over it with dinitrol or something like that also not sure what parts I should not put underseal on any advice would be great thank you dawn
Last edit: 05 May 2019 17:02 by Cremator1.
  • Cremator1
05 May 2019 17:09 #207389 by Cremator1
Replied by Cremator1 on topic Under sealing
Well I pretreat the rust so drying now what do you all recommend for which underseal to use I was going to use dinitrol.many thanks dawn
05 May 2019 17:57 #207395 by Scimike
Replied by Scimike on topic Under sealing
I would just use a wax over everything you can see with the exception of the exhaust, engine, wheels and brakes. Dinatrol / waxoil etc will be fine.
  • stiffsteve204me
05 May 2019 18:04 #207397 by stiffsteve204me
Replied by stiffsteve204me on topic Under sealing
Cremator1 wrote: Well I pretreat the rust so drying now what do you all recommend for which underseal to use I was going to use dinitrol.many thanks dawn
This is a topic that has been raised before.
Have a search, and you will find a few choices.
Personally, I am going to use Bilt Hamber, Dynax UC, and Dynax S-50.
Steve.
  • Cremator1
05 May 2019 19:00 #207405 by Cremator1
Hi scimike ok thank u do I need to do in the engine bay or will that be ok
05 May 2019 20:26 - 05 May 2019 20:27 #207410 by Scimike
I personally would stay away from the engine bay, mainly as when I did mine I sprayed it on using a Shultz gun, it throws it everywhere.
So avoid things that get hot or rotate.
Axles, shocks, training arms and every panel underneath you can see etc are all ok to do.
Also if you can get some in the box sections of the chassis and body mounts. The drain holes make perfect access points, but just make sure when you have finished they are not blocked with wax.
Don't forget the front body mounts and just under the headlamps.
It's a messy job, so park over ground you don't care about or use a sheet to cover the floor.
Also have a good laugh at yourself when you have finished, you will look like the underside of the Jimny.
PS yours is not bad in the photos, wax should protect it nicely.
GEN4 owners have a look at the pictures of the surface rust on the welds etc, these are the locations you will see rust first, some visable on GEN3s I have seen at just over 12 months old. Hope the GEN4 is better, but the pictures are a good example of what to look for.
Last edit: 05 May 2019 20:27 by Scimike.
The following user(s) said Thank You: stiffsteve204me
Time to create page: 0.109 seconds
