Re:Re:Help needed - load banging when setting off
30 Apr 2019 12:04 #206970
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Help needed - load banging when setting off was created by me101
Hi, not sure what I have broken! Had 3 days in Wales - great fun playing with the Land Rovers. Strata was no where near as scary as I was expecting with water (did this Friday before the storm dumped a load of water) and the bomb hole. However, we now have an issue. You can set off fine if slipping the clutch in, and will accelerate no problems. But, if you try and set off with any rush, or a hill start, there is a very loud banging noise coming from underneath! Otherwise, drives fine. Had it on the drive yesterday, and can get it to make the noise going forward or backwards, in 2 or 4WD. Suggestions please!
30 Apr 2019 12:10 #206971
Replied by mlines on topic Re:Help needed - load banging when setting off
Transfer box chain slipping
30 Apr 2019 12:21 #206972
by me101
Replied by me101 on topic Re:Help needed - load banging when setting off
That was my thought, but it has only done 56k (57 plate) and not really had a hard life. It does seem directly below where I am sat, but had someone listen and they think it is forward of the transfer box?
30 Apr 2019 12:36 #206973
Replied by mlines on topic Help needed - load banging when setting off
Transfer box mount gone, mini prop hitting car under load
30 Apr 2019 12:52 #206975
by me101
Replied by me101 on topic Help needed - load banging when setting off
Hopefully! Will investigate and advise! Cheers
01 May 2019 10:33 #207061
by me101
Friend went to have a look yesterday while I was at work - apparently more water than oil came out the transfer box! Looking for a 2nd hand box to replace - any suggestions where to get for sensible money and quickly. Will keep old box and look to repair if poss, maybe upgrade chain. Cheers
