Another rust prevention thread
25 Apr 2019 18:26 - 25 Apr 2019 18:29 #206661
by Scimike
Replied by Scimike on topic Another rust prevention thread
Tricky one this as everyone will have selected the best option for rust prevention, so you are going to get a few different suggestions.
It's fair to say that doing anything, even the sheep walking, is going to be better than leaving it to Suzuki's protection.
Have to say that you can get better than sheep. I have had great success with BLACK Waxoyl as an underbody spray. I used it on my Land Rover to protect the chassis several years ago and it's still doing its job. It's cheapish than other products (£20 for 5ltr) if you shop around and can be applied neat with a underseal gun from machine mart etc.
www.machinemart.co.uk/p/clarke-cub3-under-body-seal-gun/
Quick to apply and drys Matt black, mud just washes off.
For the inner box sections Dinatrol or blithamber products are easier to apply in my opinion. I used Dinatrol cavity wax areosol spray cans (500ml) with 90cm Lance to inject the box sections, doors etc on my Jimny. It took just under 4 cans.
So for me Waxoyl underbody, Dinatrol box sections etc.
I don't have any sheep to use for rust proofing.
Mike
Mike
Last edit: 25 Apr 2019 18:29 by Scimike.
- Bill Portland
- Thank you received: 77
25 Apr 2019 18:52 #206662
by Bill Portland
Replied by Bill Portland on topic Re:Another rust prevention thread
Is all this really necessary with a 12 year antiperforation warranty? Or does that only cover body panels?
25 Apr 2019 19:02 - 25 Apr 2019 19:18 #206663
by Scimike
Replied by Scimike on topic Re:Another rust prevention thread
They rot from the inside out, so visually they look good on the outside. Not a problem if you swap your your car or don't intend to keep it.
My 2009 at 8 years old had a rotten front body mount, about 4 inches of double skin metal missing. It looked perfect on the outside, but I needed remove plastic trim to find the true rust levels. I guess after 12 years it would have appeared as the headlamp falls off :laugh:
Suzuki IMHO have poor rust protection compared to other manufacturers, so if it's a keeper it's worth it.
A Suzuki has the honour of being the only classic car Wheeler dealers (restoration show) failed to repair due to rust.......and that's amongst a shed load of British Leyland rot boxes.
Personal wants and needs I suppose at the end of the day.
Last edit: 25 Apr 2019 19:18 by Scimike.
The following user(s) said Thank You: Bill Portland
- Thank you received: 2004
25 Apr 2019 19:56 #206665
Replied by Lambert on topic Re:Another rust prevention thread
The thing is that to date every vehicle I have looked after for the last 15 years has been waxed yearly because it doesn't break the bank, but in more recent years there has been a prevalence of significantly higher tech and more expensive alternative solutions for the same problem. A very major part of me is intent on continuing to use waxoil especially on a not new car and taking into account the significant cost advantage and the need to reapply yearly because of the scouring effect of long grass on leading edges. I know that sounds a lot like my mind is made up but if there is compelling evidence that these modern and more expensive solutions work better or last longer then I will change my mind...
- G-imny
25 Apr 2019 20:52 #206671
by G-imny
Replied by G-imny on topic Re:Another rust prevention thread
Reading this thread I am now concerned I should have arranged some sort of treatment for my car from new. At 4 months old is it still worth considering the more expensive treatments or should I just get it waxoyled sharpish? (Hopefully this is still relevant to the intent of the thread)
25 Apr 2019 21:13 - 25 Apr 2019 21:42 #206672
by Scimike
I don't know is my honest answer.
If you believe the hype then Suzuki may have improved things on the new Jimny.
If you go by past Jimny / SJ examples it's still poor by other manufacturers standards
I noticed on a year old demo GEN 3 model rust starting to appear on welds on the chassis, the first signs of scabby rust. Ironically the chassis is thick enough not to be an issue until the vehicle is quite old, but I was surprised to see surface rust on such a new model. Every other Jimny I looked at confirmed various levels of surface rust appearing.
If I owned a new Jimny I would keep a close eye on it and if I detected surface rust appearing (as I have seen on newish GEN3) then yes I would get it treated. BUT I tend to keep my vehicles if they are reliable for a long time, so this action is good for me.
If I intended to sell it on within 10 years then I would not bother, it's not going to add any value and the rot (if any) is not going to be my problem.
Only time will tell with GEN4, but don't panic, is not going to fall apart overnight. Enjoy what is a great looking fun vehicle...
Last edit: 25 Apr 2019 21:42 by Scimike. Reason: It's not going to fall apart
Time to create page: 0.127 seconds
