Re:How do we fit a gen 4 reversing camera? And any other mod parts.
  • Andy2640
24 Apr 2019 20:50 #206617 by Andy2640
Soeley wrote:
Andy2640 wrote: Hi guys,
Are they instructions for the Jimny though? As in... what panels to take off etc?
Sorry for the questions (like constantly) I am a lowly support worker, not a mechanic. #MonkeyMachanic :woohoo:
The Camera instructions, told what panels to remove, where to route and clip the wires to (cable ties provided with the kit), I found them very good and easy to follow.
Thats good to know Soeley. I'll document via pics the fit when i get round to it.
Nice1.
  • Andy2640
25 Apr 2019 07:51 - 25 Apr 2019 07:58 #206631 by Andy2640
mlines wrote: All the kits seem to come with instructions
Hya Martin. Hope your well.
Martin....have you got any Rear cams in stock buddy? And have you got the rear speaker mounts in stock please?
EDIT: Scrub that, just actually read the details. So around a 3 week wait. Ok, ill pop my order in later this week then i think.
Thanking you kindly!
Last edit: 25 Apr 2019 07:58 by Andy2640.
  • Andy2640
25 Apr 2019 07:59 #206632 by Andy2640
Just seen this. A great article/instructions on fitting the rear speakers on the gen 4.
www.bigjimny.com/mediawiki/index.php?tit...Speaker_Installation
25 Apr 2019 11:49 #206637 by mlines
I have a box arriving from Suzuki tomorrow, not sure what is in it unfortunately until it arrives. I have some pre orders to fulfil from it if it does contain 2019 parts but there was some "stock" in there
The following user(s) said Thank You: Andy2640
  • Ash97x
25 Apr 2019 12:50 #206639 by Ash97x
Here’s a quick guide to changing out the fog lights on the Gen4 Jimny for LED equivalents.
John Phillips has added a nice Wiki in the Gen4 section on how to change the DRL’s. The procedure is the exact same, however here it is again for the fog light specifically in case you struggle to find it.
Tools required:
• Flathead screwdriver
• 2 x LED H8/H11 bulbs (I got mine from Amazon - www.amazon.co.uk/gp/aw/d/B07C1269CZ?psc=...pop_mob_b_asin_title )
(If changing out the DRL’s too which I have done you can find them at - www.amazon.co.uk/dp/B072XL5374?ref_=pe_3...264767211_E_301_dt_1 )
Procedure:
1) Start engine and turn the wheels towards the side you are facing on, then switch off.
2) Remove the 4 pop rivets (indicated by red arrows) using a flathead screwdriver, take care not to break them. Remove the single cross-head screw that holds the fender to the front lip (indicated by blue arrow) - keep the metal clip that comes off with this.
3) Pull the fender towards you and you will reveal the fog light (green arrow) and DRL housing (yellow arrow) Unclip the connector from the fog bulb by squeezing the clip together (red arrow). Rotate the bulb counter-clockwise and it will come off. Replace with new bulb and turn it clockwise to fit it in place.
Reconnect the electrical connector. You can change the DRL’s too whilst here
4) Refit the fender by pushing it back in place. Refit the pop rivets and cross-head screw.
5) Rinse and repeat for the other side. Here’s a comparison to the stock fog (right) versus the new LED 6000K bulb (left). Quality.
6) All done. Get yourself a brew and admire your work ;)
Here’s a comparison of the bulbs. Left is the stock halogen, right the new LED equivalent.
Hope this helps folks, any queries just shout
Ash
25 Apr 2019 15:44 #206643 by Bill Portland
^^^ that's gonna be my first mod ^^^
The following user(s) said Thank You: Ash97x
Time to create page: 0.915 seconds
