Diff
- Mole
23 Apr 2019 12:47 #206534
by Mole
Diff was created by Mole
My rear diff has a bit of slop ie. When in slow traffic on and of the clutch it knocks a little I was wondering as I can't find any thing on it, can the diff be shimmed to take the play out and if so how easy is that to do.
- Thank you received: 2004
23 Apr 2019 13:13 #206535
It can be adjusted but it is fairly specialised work getting the backlash right. A gearbox rebuild place would be a good start. Alternatively you may find a good second hand one for less than a rebuild. Alternatively alternatively you could always go for it and get something interesting built up like an automatic torque bias lsd or a locking one?
- Mole
23 Apr 2019 14:52 #206539
by Mole
Replied by Mole on topic Diff
Right ok I was hoping maybe it might be a bit simpler than that but thank you. I don't have the beans to go for an built locking diff. I think its ok for the moment just putting feelers out for if and when really
23 Apr 2019 17:08 #206545
Its worth taking the rear prop off and seeing if the play is in the t-box, prop or diff first before taking it all apart to swap a diff and not fix the problem.
The rear prop should have grease nipples for the sliding part (maybe the UJs as well?). that is worth a look also.
- Thank you received: 706
23 Apr 2019 18:41 #206551
Replied by jackonlyjack on topic Diff
Yes mine suffered the knock as you put it
It stopped when i fitted new HD props
So has Riccy says check before you start spending
- Mole
23 Apr 2019 20:02 #206555
by Mole
That's great thanks all
Time to create page: 0.095 seconds
