Gen 4 towbar
  • Aj4x4
14 Apr 2019 20:43 #206121 by Aj4x4
Gen 4 towbar was created by Aj4x4
Has anyone ordered or had a towbar fitted to their Gen4? I have been told that I can only have 13 pin electrics and will need a converter from 13 to 7 pin. I only need 7 pins and feel paying for 13 is a rip off. Anyone know or had different?
14 Apr 2019 21:01 - 14 Apr 2019 21:02 #206123 by Gadget
Replied by Gadget on topic Gen 4 towbar
Correct, Suzuki only offer a 13pin electrics kit, which makes sense as most modern stuff uses that connector (and the connector itself is better). 7 pin adapters cost a fiver on Amazon, so not exactly a big deal.
Last edit: 14 Apr 2019 21:02 by Gadget.
  • Aj4x4
14 Apr 2019 21:03 #206124 by Aj4x4
Replied by Aj4x4 on topic Gen 4 towbar
Thank you for the info. I have an adapter already......so all good.
15 Apr 2019 04:05 #206128 by Lambert
Replied by Lambert on topic Gen 4 towbar
Be aware that the 13 pin is electronically tested at the mot. 7 pin is just visually examined. Consequently the 13 pin needs to be kept in good clean working conditions even if it is only used once a year for the caravan.
  • Aj4x4
15 Apr 2019 18:25 #206150 by Aj4x4
My son does all my MOTs and wont need one for three years.... but appreciate the advice.
  • CC Baxter
17 Apr 2019 13:32 #206281 by CC Baxter
Replied by CC Baxter on topic Gen 4 towbar
Sorry, no hot-wire. I fitted the genuine Suzuki item which includes a wire to run to the fuse box behind the glove box. The 13 pin Suzuki kit is quite expensive at £125 but fitting is fairly easy.
CC Baxter
Time to create page: 0.104 seconds
