Viscous fan
- Thank you received: 2004
13 Mar 2019 06:48 #204508
Viscous fan was created by Lambert
Hi all. Having dropped a hundred quid into a new viscous coupling and therefore having a spare I figured that the broken one isn't going to be any less broken if I take it apart and try to fix it. I blame YouTube. Ok so basically they rely on a specific volume of a specific grade of silicone oil being sheared by the moving parts inside the assembly, this is in turn controlled by the action of a bimetallic coil acting on a valve to offer a temperature variability. Still with me at the back?
At the moment I'm still researching the actual volume and grade of oil Suzuki recommend?
Having split my one I have found a decided absence of any oil at all, just a thin smear. So having done some research the oil is the stuff that rc cars have in their dampers and is readily available in many grades. Win!
Apparently Toyota use a 3000 grade in the cruiser and it is a thing to tune the fan lock up using a higher or lower grade of oil. Obviously this depends on the Suzuki spec but it can't be far off and is worth exploring.
Next couple of days if I get chance I will bob over the hill to modelsport and get some supplies in and report back.
13 Mar 2019 07:27 #204509
Replied by Lambert on topic Viscous fan
Once I have found something out I'll see if I can work the wiki and pop the findings in there. Or I'll pin this to the top. We'll see.
- JimJimny
13 Mar 2019 07:42 #204510
by JimJimny
Apologies for the off-topic request here, but wonder if while you're over at otley you might ask them whether/when they'll be getting the gen4 Jimny crawler . . I might have more luck getting one of those before the real thing arrives, at this rate of (non)progress! :S
Wishing you success with the oil hunt for the coupling.
Replied by JimJimny on topic Viscous fan
Lambert wrote: Next couple of days if I get chance I will bob over the hill to modelsport and get some supplies in and report back.
13 Mar 2019 08:07 #204512
No worries. I was going to be asking about a gen3 anyway so I will see what's what.
13 Mar 2019 12:57 #204519
All they have is the tamiya gen3 kei model with ifs and rigid chassis. Though the shell is available separately and could be mounted to a more capable traxxus chassis. Not aware of a gen4.
- JimJimny
13 Mar 2019 13:14 #204520
by JimJimny
Thanks, I'm much obliged to you for asking . . I've seen the gen3 model on their website, was just hoping they might know of any plans to introduce a gen4 model., Maybe it'll happen if the manufacturers think there would be sufficient demand, although that doesn't seem to have happened with the Suzuki real m'coy.
Time to create page: 0.176 seconds
