More expense.
- Max Headroom
- Banned
- Thank you received: 217
19 Feb 2019 20:06 #203476
by Max Headroom
Replied by Max Headroom on topic More expense.
I had a similar issue with my'79 MG and connected the heater matrix to an outside tap and flushed the system in both directions and was astonished at the muck that came out
I know these are two different animals but it may help - just dont over-pressurize it.
- Thank you received: 1999
20 Feb 2019 04:57 #203505
Replied by Lambert on topic More expense.
At this point I'm inclined to give it a go. I'll see what has happened over night and give it some more thought.
20 Feb 2019 07:58 - 20 Feb 2019 08:00 #203510
by kirkynut
Replied by kirkynut on topic More expense.
Perhaps solve the airlock issue before changing the radiator.
Did you have the heater on hot when you re-filled it?
From where you are now, put the heater on fully hot, start her up, take the rad cap off and keep gently squeezing both upper and lower radiator hoses to expel air.
Top up coolant as necessary and do this until the thermostat has opened and both radiator hoses are hot.
If it has surpassed 98' and started to go down from the cooler water in the radiator but is then not holding a stable temperature I'd then start to consider changing the radiator and going through the above procedure as you re-fill it.
After this it can only be the fan. I think Martin found a way of locking it up once but it's a long time since I read it. It may have been transferred over to the Wiki.
Last edit: 20 Feb 2019 08:00 by kirkynut.
20 Feb 2019 08:29 #203512
The new ish rad is already in. What I might try next is a dose of system clean and repeated clean water flushes just to be sure there's no build up of deposits though I can't see how.
20 Feb 2019 09:50 - 20 Feb 2019 09:51 #203520
by Scimike
Replied by Scimike on topic More expense.
Reference to viscous fan coupling......noticed that normally when you start the Jimny the font AC fan will turn quickly due to air being drawn from the viscous fan, then after about 30 it will stop turning as the viscous coupling releases the main fan.
This is due to the coupling being "locked" from the day before use at start, it releases as the engine is now cool to assist warm up.
Just trying to help with an observation that happens on a working engine.
Good luck
Mike
Good luck
Mike
Last edit: 20 Feb 2019 09:51 by Scimike.
20 Feb 2019 14:29 #203533
Getting somewhere now. Topped up via the top hose with cleaning fluid and ran up to temperature as directed maintaining a stable 86 87 and the heater is too. Just dropped the cleaning fluid and no sludge or garbage. Given a clean water flush and drain and another to be sure and then fill with red oat. Looking promising.
Time to create page: 0.329 seconds
