Gearbox inspect / drain
  • Halbblut
05 Feb 2019 14:47 #202619 by Halbblut
Gearbox inspect / drain was created by Halbblut
Hello,
I am looking to inspect the oil on my Jimny's gearbox. I have taken a look at the location of the level/refill plug on the gearbox. My question is due to the fact that there is very little room between the refill plug and the side of the tunnel, how do I get a torque wrench on the plug to tighten to correct torque?
I have a square drive for the oil plugs but by the time I place the drive in the plug the is so little room left to get the torque wrench in.
Any advice or help regarding this would be most appreciated.
Thank you in anticipation.
Regards
05 Feb 2019 14:51 #202620 by Lambert
Replied by Lambert on topic Gearbox inspect / drain
Hmmm. I have a 1/4 drive torque wrench that does fit but I just tend to nip it up by hand ?
The following user(s) said Thank You: Halbblut
  • Halbblut
14 Feb 2019 18:51 - 14 Feb 2019 18:52 #203228 by Halbblut
Replied by Halbblut on topic Gearbox inspect / drain
I got a 1/4 inch drive torque wrench and succeeded in removing and replacing the gearbox fill plug. With room to spare. Cheers
Last edit: 14 Feb 2019 18:52 by Halbblut. Reason: Mistake
14 Feb 2019 19:20 #203229 by kirkynut
Replied by kirkynut on topic Gearbox inspect / drain
Just nip it up tight but don't over do it. Once it's starting to tighten, just give it a little nip and it'll be fine.
Time to create page: 0.082 seconds
