cargo jimny
- Vagus
03 Feb 2019 17:14 #202454
by Vagus
cargo jimny was created by Vagus
Hello to the forum from Athens Greece
I would like to ask a few things about this little monster.
Well three years ago I bought a jimny mod 2000 without any modification.
I use this car for my job (building renovation) and I carry heavy load almost all the time in addition of towing a heavy trailer with all my tools.
I would like to take some advise from the experts for what can I do with jimny s suspension because it is compressed all the time from the extra weight especially to the back.
I think about coil spacers and shock spacers about 40mm to avoid castor correctors and adjustable panhard bars and longer brake hoses.
Is the 40mm the limit for this?
Should I do my job with the spacers cheap and easy without other mods?
somewhere I read that another solution is to put the front coils to the back.
If you have time give me an answer
Thank you very much
Vagus
Thank you very much
Vagus
03 Feb 2019 17:27 #202456
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Re:cargo jimny
Welcome
I would have thought you could buy some heavy duty springs to handle the weight in the rear.
- Thank you received: 2004
03 Feb 2019 17:42 #202459
Replied by Lambert on topic Re:cargo jimny
Welcome to the forum. If it's just for the extra weight in the back then fitting a pair of standard front springs in the back will give a small lift to compensate for the load.
The following user(s) said Thank You: Vagus
- Max Headroom
- Banned
- Thank you received: 216
03 Feb 2019 18:33 - 03 Feb 2019 18:33 #202464
by Max Headroom
Replied by Max Headroom on topic Re:cargo jimny
Welcome to the forums Vagus
I'm sure you will get all the answers you need here
Last edit: 03 Feb 2019 18:33 by Max Headroom.
- Foxtrot
03 Feb 2019 18:49 #202466
by Foxtrot
Replied by Foxtrot on topic cargo jimny
Caravaners use these to stop the springs from bottoming out.. I have never used them, something else to consider?
www.towsure.com/towing-spring-assisters
03 Feb 2019 19:21 #202473
Replied by yakuza on topic cargo jimny
Those inserts in between the spring rings would damage more over time than they help, as they would relieve parts of the spring, while the rest of the spring get more pressure and load..
Best is to use a stronger spring. A spring seat spacer could help a bit, but will not increase the load carrying capability.
Time to create page: 0.105 seconds
