Tyre pressures
  • Cremator1
03 Feb 2019 09:33 #202420 by Cremator1
Tyre pressures was created by Cremator1
Hi all just fitted 205/75 /15 At3 general grabbers what pressure do you find best to run them at many dawn
03 Feb 2019 09:49 #202423 by sniper
Replied by sniper on topic Tyre pressures
Try a few is my advice..
20psi, 22psi and 24psi would be a good spread. see what suits you and how the car responds. Anything above 25psi makes my AT's too stiff and it bounces off speed bumps and potholes.
If you take the time to try a few different pressures, you will find a sweet spot where you are happiest.
sniper
03 Feb 2019 09:52 #202424 by adrianr
Replied by adrianr on topic Tyre pressures
Good advice from Sniper.
I varied mine a bit to find what worked best for me. I run Hankook Dynapro ATM 195/80 R15 and find 22 psi front 24 psi rear gives a nice ride. Anything higher and it feels skittish and bouncy.
  • Cremator1
03 Feb 2019 09:56 - 03 Feb 2019 09:56 #202425 by Cremator1
Replied by Cremator1 on topic Tyre pressures
Hi guys ok will start with 20psi at mo got 25 in and feels a bit bouncy is that 20psi all round
Last edit: 03 Feb 2019 09:56 by Cremator1.
03 Feb 2019 10:04 #202427 by Lambert
Replied by Lambert on topic Tyre pressures
I have just swapped the tyres between my 2 and when measuring the tread depth found that the 26 psi I had been running in the back was taking the centre out of the tyres. I'm now at 23 psi front and back and the ride is much improved. I have no back seats and only rarely have a full load for any length of time, mostly running empty.
  • Cremator1
03 Feb 2019 10:06 #202428 by Cremator1
Hi lambert are they the same size as mine
