Gen 4 Tyre Pressure
26 Jan 2019 12:32 #201742 by Soeley
Gen 4 Tyre Pressure was created by Soeley
Has anyone checked their tyre pressures?
The label on the drivers door post says 26psi front and rear. Just checked mine with my digi gauge and they are up to 38psi, surely the dealer couldn't get them that wrong?
I would be interested to see what other peoples tyre pressure are set at from the dealer.
26 Jan 2019 12:45 #201743 by Busta
Replied by Busta on topic Gen 4 Tyre Pressure
This has always been a problem with the Jimny. Garages and tyre fitters never check the required pressure and over inflate the tyres, leading to a bumpy ride and skittish handling.
26 Jan 2019 15:38 - 26 Jan 2019 15:38 #201749 by Max Headroom
Replied by Max Headroom on topic Gen 4 Tyre Pressure
The garagfe that serviced my neighbour's Jimny did that - it almost put her in the ditch!
After a serious rebuke, they have revised their bad practices
Last edit: 26 Jan 2019 15:38 by Max Headroom.
  • TaterTot
26 Jan 2019 15:54 #201751 by TaterTot
Replied by TaterTot on topic Gen 4 Tyre Pressure
Same here. Valve on one of the tires started leaking, so had to change it. 5min job at the garage, but that was one uncomfortable tire to drive with afterwards. Same thing happened last time i changed tires. We just got to learn to look after this on our own I guess.
26 Jan 2019 17:06 - 26 Jan 2019 17:07 #201758 by Soeley
Replied by Soeley on topic Gen 4 Tyre Pressure
Not having had TPMS before, I thought it it have warned of over inflation. Have deflated them down to 26psi now.
Also looked at the PDI tick sheet, couldn't see 'Check tyre pressure' on there.
Last edit: 26 Jan 2019 17:07 by Soeley.
26 Jan 2019 17:32 #201763 by reedx
Replied by reedx on topic Gen 4 Tyre Pressure
Soeley wrote: Not having had TPMS before, I thought it it have warned of over inflation. Have deflated them down to 26psi now.
I'm sure I've read that TPMS warn when tyre pressure drops below a certain preset level.
Colin
Time to create page: 0.103 seconds
