Jacking and recovery
- Thank you received: 2004
11 Jan 2019 18:23 #200481
Jacking and recovery was created by Lambert
I may have asked this years ago but that was then. What is there in the way of recovery points that incorporate a high lift jack point front and rear? I know that jimnybits do theirs but they don't have jack tubes? I'm not wanting a pair of full bumpers just small discreet projections through the plastics. What is there?
- Thank you received: 706
11 Jan 2019 18:42 #200484
Replied by jackonlyjack on topic Jacking and recovery
nothing I've ever seen as a recovery point
Only rock sliders with Hi lift points
I can lift my rear end one side at a time with Hi lift under the recovery points i made
11 Jan 2019 18:56 #200488
Replied by Lambert on topic Jacking and recovery
Hmmm I guess I could always modify the jimnybits ones with some heavy wall pipe?
11 Jan 2019 19:13 #200496
Possibly only issue i can think would be is that the bumper tops stick out a fair bit from the recovery points
also the rears sit horizontal
fronts sit vertical so could possibly weld a tube to the under side
11 Jan 2019 19:31 #200502
Replied by Riccy on topic Jacking and recovery
pretty sure you can get a shackle adapter for a high lift jack
The following user(s) said Thank You: jackonlyjack
11 Jan 2019 19:38 #200503
Ooh a shackle attachment sounds interesting, will have a look for one.
Time to create page: 0.113 seconds
