2.0 GV engine
- Johnniehec
Topic Author
- Thank you received: 56
06 Jan 2019 23:11 #200104
by Johnniehec
2.0 GV engine was created by Johnniehec
What type of engine is in a 2002 2.0 petrol Grand Vitara? Any good for a transplant? Cheers
John.
John.
- Thank you received: 2004
07 Jan 2019 04:58 #200108
Replied by Lambert on topic 2.0 GV engine
As I understand it that falls into the anything is possible camp for donor engines, it's possible just not straightforward.
- Thank you received: 227
07 Jan 2019 05:07 #200109
by zukebob
Replied by zukebob on topic 2.0 GV engine
For a 2002, it should be a J20. I've never seen any information on a Jimny swap.
07 Jan 2019 19:30 #200141
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic 2.0 GV engine
If my research is correct, It is the same bolt pattern as a 1.6 Vitara G engine. So would work with a jimny box with an adapter, or drill the holes out.
The stumbling block is the flywheel, Too big for the Jimny box. The jimny is six bolt and the J20 is eight, So can not be swapped. There are some other options and when ive sussed it out i'll post it up, As the options are rare and hard to come by. Also you would need to use the J20 ecu or complete loom, Or a stand alone ecu.
07 Jan 2019 20:12 #200146
Would it be simpler to use the vitara main box and engine as a unit with ecu and adapt the tunnel to accommodate? Or is that too obvious?
08 Jan 2019 00:54 #200152
by zukebob
When I was first looking at this, the best information I found was here:
J20 into a Suzuki Samurai
It's still an apples and oranges comparison but does provide some info.
One of the first stumbling blocks that many Jimny owners will face is the legality issue of downgrading the engine (unless you have a 2002 or older Jimny). Even here in the Philippines (classed a developing nation) you can't put an engine into your vehicle that is older than the vehicle production year.
Time to create page: 0.092 seconds
