2wd 4wd
  • Cremator1
13 Dec 2018 20:04 #198932 by Cremator1
2wd 4wd was created by Cremator1
Hi all can you really switch between 2wd and 4wd while you are on the move or will it damage something
Many thanks dawn
13 Dec 2018 21:31 #198934 by Busta
Replied by Busta on topic 2wd 4wd
Yes, at up to 60mph! Instructions are on the sun visor.
13 Dec 2018 21:40 - 13 Dec 2018 21:43 #198935 by Scimike
Replied by Scimike on topic 2wd 4wd
Yes you can, I have done it once at about 20 mph, in and out of 4WD. O
Having done it once I will never be doing it again. It was too "mechanically unsympathetic" for me.But have a go, nothing should break.
Remember to only do it on ground with reduced traction, its not for use on grippy tarmac :)
Last edit: 13 Dec 2018 21:43 by Scimike.
13 Dec 2018 23:13 #198938 by Busta
I do it every day whilst moving at speed and have done it at 60mph more than once. I've also done it on grippy surfaces, while turning and in conditions when the rear wheels are already spinning slightly. Every time it goes into and out of 4wd quite happily with a reassuring clunk-clunk from the front hubs.
The only time it's made any complaint is once when drifting on a stubble field very sideways with the rear wheels going possibly 20mph faster than the fronts I thought 'I wonder what will happen if....'. I pushed the lever, the dog clutch in the transfer case banged a couple of times, struggling because of the speed differential, before engaging as normal and all 4 wheels starting to spin. It has continued to work reliably every since.
If you have the older model with the gearstick for the transfer case, with a little bit of practice you can also switch between low and high whilst moving. I do that most days too.
I've found it to be a robust and very convenient system and I suspect the few issues people do experience are most likely caused by infrequent use.
14 Dec 2018 05:59 #198940 by Max Headroom
Replied by Max Headroom on topic 2wd 4wd
Someone else will correct me if I'm wrong here, but I'm sure if you are engaging/disengaging 4L that you should be stationary
14 Dec 2018 06:02 - 14 Dec 2018 06:04 #198941 by yakuza
Replied by yakuza on topic 2wd 4wd
I would not recommend changing into low gear at speed.
I done this while sliding forward with brakes locked sometimes but then it is kind of stationary..
Beware it would not be smart to change between 2wd and 4wd if you have manual hubs and have forgot to engage them.
Second that with the infrequent use especially with the vacuum system. The hubs will not give you any problems with frequent use and lubrication. The same with the push button transfer case.
Last edit: 14 Dec 2018 06:04 by yakuza.
Time to create page: 0.101 seconds
