Broken cross member
- Mole
04 Dec 2018 10:26 #198609
by Mole
Broken cross member was created by Mole
As in the title I found after I bough my jim that the rear panhard rod mount its cross member was broken I haven't a clue how you manage that but there we go all fixed now tho ☺️
- Thank you received: 706
04 Dec 2018 15:41 #198623
Replied by jackonlyjack on topic Broken cross member
Looks like a good quality fix that
And may i just say you could do with a
L shaped bracket on top of axle so the spring sits level
- Mole
04 Dec 2018 16:26 #198625
by Mole
Replied by Mole on topic Broken cross member
Cheers. Where abouts we talking for the bracket? As I can't see for looking ☺️
04 Dec 2018 17:10 #198632
On top of the diff it's held on with a 6mm bolt 10mm spanner size
It's a small L shape with spring attached
If you have a lift kit fitted say 2" then you need to lift the spring to match
But if in the picture your axle his hanging down with no lift kit just ignore ME lol
- Mole
04 Dec 2018 17:18 #198633
by Mole
Ah ok I see it now thought you ment the big spring. I have a 2 inch lift so I'll make one up. Next question what is it and what dose it do lol
04 Dec 2018 17:26 #198635
It to compensate the rear braking system
not sure how it works tbf
Mine has ABS so it's not got one fitted
Time to create page: 0.124 seconds
