Air con
- Cremator1
01 Dec 2018 17:16 #198484
by Cremator1
Air con was created by Cremator1
ok So thought I would try air con on new jimny today switched on all worked but lifted bonnet and noticed every 10/15 seconds you hear a click fan would run then click off should it do this many thanks dawn
01 Dec 2018 17:35 #198486
Sounds good. The click will be the compressor magnetic clutch pulling in/out as its needed, which results in the electric fan at the front coming on/off.
The compressor is located on the right at the bottom (passenger side of UK vehicle, same belt as the power steering pump, below it). This is where you should be hearing the click from.
The magnetic clutch in the compressor saves fuel by only running the compressor when needed (less load on the engine belts). On a hot day the compressor would be engaged a lot more, even more so in traffic.
- Cremator1
01 Dec 2018 17:39 #198487
by Cremator1
Replied by Cremator1 on topic Air con
Hi oh ok car engine was cold and it was just ticking over yes that’s where I can here the clicking it just seems to be a lot of clicking in and out never heard this on my other car well heard it click but not as much as this it is blowing cold air and pipes are cold
- Leighlo
01 Dec 2018 20:05 #198499
by Leighlo
Replied by Leighlo on topic Air con
Sorry to hijack the thread but I’ve got the feeling mine doesn’t click off, any ideas?
The compressor runs constantly and is freezing up the air con pipes and heater matrix
- paradox1001
01 Dec 2018 20:08 #198500
by paradox1001
Replied by paradox1001 on topic Re:Air con
Sounds like the clutch maybe stuck
- Max Headroom
- Banned
- Thank you received: 216
02 Dec 2018 21:23 - 02 Dec 2018 21:23 #198554
by Max Headroom
Replied by Max Headroom on topic Re:Air con
Top-tip...(sorry if you already knew this)
Just a thing an American friend once told me, and I have heard it from other people since, and that is, those with A/C should run the system for at least 10 mins every few weeks on full-cold to keep it in good condition EVEN IN WINTER!.
This allows the coolant to circulate through the system and keep the rubber seals from drying-out and causing leaks
Last edit: 02 Dec 2018 21:23 by Max Headroom.
Time to create page: 0.108 seconds
