Replacement Antenna
- ChrisW
28 Nov 2018 14:02 #198272
by ChrisW
Replacement Antenna was created by ChrisW
hey guys,
Anyone found a replacement antenna for the Jimny? Mine isn't physically broken, however I get no signal out of it what so ever. I have seen this:
3d-4x4.com/products/suzuki-jimny-aerial-...a-direct-replacement
Which a) is in dollars, b) has no contact info to ask if they ship to the UK and c) its just a 3D printed part so longevity will be an issue unless its soaked in epoxy.
Thanks
Chris
Thanks
Chris
- Max Headroom
- Banned
- Thank you received: 217
28 Nov 2018 17:41 - 28 Nov 2018 17:41 #198284
by Max Headroom
Replied by Max Headroom on topic Replacement Antenna
Chris
I know this is a different situation, but my neighbour had a DAB radio put in by Halfords, they fitted an almost invisible aerial to the windscreen which works superbly.
I'm not sure if they disconnected the original aerial or if that is still required to reeceive FM but I don't see why the new DAB aerial in the windscreen wouldn't also do the job for FM.
I certainly wouldnt go through the hassle and expense of importing a component like this uneccessarily - the chances are you may get stung by import duties as well.
Last edit: 28 Nov 2018 17:41 by Max Headroom.
28 Nov 2018 21:57 #198311
by Delux
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
Replied by Delux on topic Replacement Antenna
I've only ever fitted ebay or suzuki replacements but the one from the states does look quite cool.
If the aerial is intact, perhaps have a look under the dash. Depending on the model, year and if someone has messed with it before, some Jimnys aerial lead plugs into an extension lead to the head unit. The 2000 Jimny I just sold had the standard unit but the lead had an extension cable.
Extension cable can fall or be kicked out, might save you some work.
On DAB systems I have worked with, most have a seperate aerial with a different connector to the usual aerial lead. If retro-fitting one, most manufacturers suggest mounting their aerial lead away from the FM aerial one.
29 Nov 2018 19:20 #198392
Replied by yakuza on topic Replacement Antenna
I bought this ebay DAB/FM antenna (british seller) to put on the roof. pretty easy install on the rear of the jimny roof. and way better reception than the glass antennas.
29 Nov 2018 20:18 #198399
by Roy
Replied by Roy on topic Replacement Antenna
Hi Yakuza
Do you have the item number for the ariel you got from ebay.
Cheers
Cheers
- ChrisW
30 Nov 2018 00:40 #198428
by ChrisW
Replied by ChrisW on topic Replacement Antenna
This is interesting, and could well be the issue. The antenna on the roof is fine, no damage at all but I get zero signal. Even radio 1 barely plays.
Car is still in the shop getting the rust repaired (they are doing it in the background when there is time as I have another car I can use)
Will dig behind the dash and see if there is a join. I am certain there will be after reading this.
To everyone else, I am not keen on buying the linked one at all, it’s expensive and it’s 3D printed. He doesn’t state what out of, which if is PLA will warp and cause your roof to leak after the first warm day.
Time to create page: 0.199 seconds
