Diff oil
25 Nov 2018 13:53 #198131 by Lambert
Replied by Lambert on topic Diff oil
Yes definitely. Using it 3/8 drive is only good if it starts to undo fairly easy. The 10mm drive is a better bet if the plug is being recalcitrant.
  • Cremator1
25 Nov 2018 13:59 #198132 by Cremator1
Replied by Cremator1 on topic Diff oil
Hi ya ok think I need to get a set u have an auto don’t u have u ever changed the gear box oil in it
25 Nov 2018 14:17 #198135 by mlines
Replied by mlines on topic Diff oil
The auto uses A/T fluid Dexron IIE
It takes about 1.1 litres but in practice, as there is no proper drain, you have to pump it out.
25 Nov 2018 14:26 #198137 by reedx
Replied by reedx on topic Diff oil
Cremator1 wrote: Ok will go for millers in diff not sure about gear box as it is auto do not sure what to use in it
I favour using Millers oils whenever possible. Very helpful technical department.
Colin
  • Cremator1
25 Nov 2018 15:38 #198140 by Cremator1
Hi thanks for the reply’s guess I will have to take it to garage for the auto box oil change
25 Nov 2018 16:09 #198143 by Lambert
I haven't had to do a box oil change on the auto yet, but I'm tempted to get someone else to do it as it's not straight forward.
Time to create page: 0.101 seconds
