trailmaster kit
  • Kenny Milne
28 Oct 2018 10:30 #197123 by Kenny Milne
trailmaster kit was created by Kenny Milne
I recently fitted a 2" Lift trailmaster kit, i now have a knocking sound from the front suspension, sounds like the springs are hitting the plastic stops that came with the kit, anyone else had experience of this. Do I need these stops.
  • TomDK
28 Oct 2018 11:54 #197124 by TomDK
Replied by TomDK on topic trailmaster kit
Where are these stops mounted?
  • Kenny Milne
28 Oct 2018 16:05 #197126 by Kenny Milne
Replied by Kenny Milne on topic trailmaster kit
On the inside the bottom of the coiled spring, where the spring is sitting on the wishbone.
  • TomDK
28 Oct 2018 16:11 #197127 by TomDK
Wishbone?
Is it a Vitara you have ?
  • X8GGY
29 Oct 2018 06:28 - 29 Oct 2018 06:32 #197139 by X8GGY
Replied by X8GGY on topic trailmaster kit
They are trailmaster's version of extended bump stops -
The plastic discs just above the brake hose in the above photo... They bolt to the top of the spring seat cones on the front axle, at the bottom of the springs where the bump stop lands... OP has referred to it as the wishbone rather than the radius arm. although the spring is actually on the axle.
The two kits I've fitted have not had them included, they are a new addition, so I can't comment on whether they catch or not?
Last edit: 29 Oct 2018 06:32 by X8GGY.
29 Oct 2018 07:21 - 29 Oct 2018 07:26 #197143 by mlines
Replied by mlines on topic Re:trailmaster kit
I have fitted them on three jimnys. They were all fine and I cannot see how they would catch anyway. I would look to see if the springs are seated correctly at both ends.
Last edit: 29 Oct 2018 07:26 by mlines.
Time to create page: 0.094 seconds
