Wheels..
  • GRAYWOLF
23 Oct 2018 13:31 #196974 by GRAYWOLF
Wheels.. was created by GRAYWOLF
Hi, does anyone know if the alloys from a suzuki vitara fat boy..8jx15 i think...would fit a jimny?
Cheers people.
23 Oct 2018 13:48 #196975 by Lambert
Replied by Lambert on topic Wheels..
The pcd is correct but they will be quite wide. Make sure they're 8j as some were 10j.
23 Oct 2018 13:53 - 23 Oct 2018 13:54 #196976 by yakuza
Replied by yakuza on topic Wheels..
Mine are 8.5 and ET35:
they poke out about two inches or so from original arches.
These came to Norway on a Vitara Fat/wide from Germany mid nineties sometime.
Totally not possible to drive with these tires.
If i had removed the jack or had air in them they would sit in the fenders with 325/60-15 tires.
used them on my 4 inch lifted and wheel well gutted SJ.
Last edit: 23 Oct 2018 13:54 by yakuza.
  • GRAYWOLF
23 Oct 2018 14:58 #196978 by GRAYWOLF
Replied by GRAYWOLF on topic Wheels..
Hi Lambert..not too fussed about being wider, as i would extend arches, 10 would be better..lol..
I am going for a suzuki 'wide' look..
As i have a 2inch suspension lift already, clearance wouldnt be a problem..not thinking of aggressive tyres, more like what i currently run but wider..
Many thanks.
  • GRAYWOLF
23 Oct 2018 15:00 #196979 by GRAYWOLF
Thanks for pics, and info, i am looking to get a wide look, as the suzuki Jimny wide..so, either 8j or 10j would be ideal..i thought pcd was same, just wondered if anyone had fitted these..i already have a 2inch suspension lift..not thinking of bopdylift..but anythings possible..
23 Oct 2018 15:14 #196980 by yakuza
with the wheel so far out in the arch you will most likely get some interference on full steer either way. Easiest way to cope with it is to cut out of the arches. Lifting will help as well but with this much offset on the wheel cutting is the best in my opinion. It will eat king pins and wheel bearings for breakfast. And enhance any trace of wobble you have from not noticeable to complete death.
But it will look fantastic :)
Very seldom to find someone who wants wider in here. As you see from my wheels i like wide. I like to float when offroad.
You can make a cardboard dummy of your tire profile from dimensions from a wheel calculator. I did this on my SJ when I cut 3 inches out of the wheel arch. Moved the bottom outer corner of the firewall back one inch. moved the front bumper forward 2 inches.. and had 4 inches of lift as well. Doing more or less the same to my next SJ.
Time to create page: 0.121 seconds
