Droop limit straps
11 Sep 2018 18:15 #195891 by Lambert
Droop limit straps was created by Lambert
Whatcha. Is there a simple place to affix axle droop limiting straps? I was thinking secured on top of chassis and then looped under radius arms?
11 Sep 2018 18:20 #195892 by Scimike
Replied by Scimike on topic Droop limit straps
I have no idea on a Jimny, but on a Series Land Rover they attached to the side of the chassis (custom mount point) and loop under the axle tube.
I don't have them on my Series, the shock limits the movement and so far its not damaged the shock in an way.
11 Sep 2018 19:07 #195896 by Lambert
Replied by Lambert on topic Droop limit straps
With my factory springs in it's not a problem as like you say the dampers limit droop while the spring is still under pressure. With my track springs there is a definite possibility of the spring unseating as I don't need to compress them to fit them and having a spring fall off in a corner would suck.
11 Sep 2018 22:19 #195908 by jackonlyjack
Replied by jackonlyjack on topic Droop limit straps
You could buy a clamp that holds the spring to the axle
Rockwatt. Jimnybits both sell them
Rockwatt's is the better design
Ask Dave Jones aka Zook bob he was selling Rockwatt's version
Jack
  • X8GGY
11 Sep 2018 22:40 - 11 Sep 2018 22:42 #195910 by X8GGY
Replied by X8GGY on topic Droop limit straps
Thanks JackOnlyJack ;)
www.ebay.com/itm/132677656086
As fitted to the rear of S200KYS -
Last edit: 11 Sep 2018 22:42 by X8GGY.
12 Sep 2018 03:25 #195913 by Lambert
They could work though they won't limit droop. Cheers.
Time to create page: 0.094 seconds
