Quaife ATB differential
13 Aug 2018 11:55 #195083 by Busta
Replied by Busta on topic Quaife ATB differential
No, they operate in completely different ways and have quite different applications.
The kaiser is a mechanical locker (not a limited slip diff) that uses an over-run mechanism that effectively removes the 'differential' part of a diff. When it is not locked, it sends the drive to only the slowest moving wheel (1 wheel drive!). When that wheel spins, or the speed of both wheels matches, it fully locks both wheels together. So it is either 1 wheel drive or locked. The benefit in a 4x4 is it will continue to drive both wheels when one is in the air, but the relatively crude form of engagement is quite intrusive when driving on the road.
An ATB (automatic torque biasing) limited slip diff operates just like a normal differential in normal driving, splitting torque equally between both wheels. When there is a significant difference in grip, the worm gears in the diff bind up and allow the diff to deliver more torque to the wheel with more grip. The diff is never completely locked, and as such will not drive both wheels if one is in the air. The effect of an LSD is barely noticeable in normal driving, hence their fitment to many standard vehicles.
  • X8GGY
13 Aug 2018 13:27 #195086 by X8GGY
Replied by X8GGY on topic Quaife ATB differential
Thanks for that explanation Busta, I've been following this thread with interest as I couldn't understand why one wheel would spin in the air if a rear wheel was off the ground... in my experience of clutch-based LSDs drive would go to the opposite wheel, i.e. the one on the ground not in the air!
Are we saying this is indeed an 'LSD' (ATB) Diff for road-b(i)ased Jimnys?! :dry:
  • X8GGY
13 Aug 2018 13:35 #195087 by X8GGY
Busta wrote: No, they operate in completely different ways and have quite different applications.
Just re-read that... so, if one wheel is in the air shouldn't it drive the one with more grip? The one on the ground? Or not as you say "...and as such will not drive both wheels if one is in the air."
More confused now? :unsure:
13 Aug 2018 14:39 #195088 by Gadget
Replied by Gadget on topic Quaife ATB differential
My understanding is that a LSD can only send some of the torque available to the other wheel - so if the wheel in the air has zero grip, then it can only send x% of zero = none. They're useful where one wheel has less traction, but not when one wheel has zero, which is where you need a full locker.
13 Aug 2018 15:48 #195090 by sniper
Replied by sniper on topic Quaife ATB differential
The effect that the diff has on a car is surprising, it behaves nothing like an LSD. No snatch as the other wheel bites at a pre set load, completely smooth. You can wake it up in tight turns, but only by pushing too hard, which you can do, even with a jimny..
It is biased towards fast tarmac cars not off roading, but I felt it would give me benefit in both and it has.
I would not suggest it was more capable than a locker but I would suggest that it would be better value to the majority of drivers.
If your car is as mine, a road car that is taken off road, it spends most of it's time on tarmac and thats where the ATB excels. In addition, it more than provides assistance, off road, win win....
I've put them in rwd escorts and caterhams to replace plated LSD's, the only negative found on a tarmac car was kerbs, where a wheel could be lifted and drive lost. Even then, the chassis benefits, outweighed the negative.
A cracking piece of kit that you need to read proper reviews about if your considering it, not my ramblings.
This diff makes an axle, be it FWD or RWD, feel like it is in charge of the vehicle. Nobody who has driven a car where the ATB has replaced an open diff or a plated LSD, would argue against that. Many who have driven it would place it in front of a plated LSD, especially for less accomplished drivers such as me.
Each piece of kit has it's place and this one has found it's home.
I was going to spend the money on an engine upgrade but old lessons came to mind and now my 86hp can feel like 200hp when conditions suit...
sniper
  • X8GGY
13 Aug 2018 16:53 - 13 Aug 2018 16:57 #195091 by X8GGY
This is my old Vitara "Superzuki" at Woodlands years ago...
That's how clutch based LSDs work... one in each end ;)
Hence why I had our Rockwatt fit my front Vitara LSD in the front of S200KYS (ARB air locker in the back)
Last edit: 13 Aug 2018 16:57 by X8GGY.
Time to create page: 0.193 seconds
