Kingpin bearings replacement - any others to replace while at it?
14 May 2018 14:01 - 14 May 2018 14:03 #192680 by kirkynut
You want some of this grease for the CV joints and kingpin bearings: www.bigjimny.com/store/waterproof-grease.html
I use these to make sure there's no slack in the new kingpin bearings: www.bigjimny.com/store/annealed-copper-shims-suzuki-jimny.html
Or you could use these shims but it can be a bit of messing about to get it right and I worry about the kingpin bearings being too tight, although you could measure the drag with a spring balance, although I'm not sure how accurate this is:
www.bigjimny.com/store/king-pin-shim-kit-suzuki-jimny.html
Last edit: 14 May 2018 14:03 by kirkynut.
15 May 2018 05:51 #192699 by farshi
I prefer buying the grease here in Israel as it's quicker and probably cheaper due to shipping cost.
What are the grease specs other than waterproof? should it be based on silicon or graphite or something else?
Basically, what should I look for at the hardware store?
I think I will be using the copper shims just to be sure.
Farshi
Time to create page: 0.168 seconds
