Easy engine identification.
02 Feb 2018 21:24 #189053 by Busta
The issue of engine identification often comes up on the forum and a common solution is for a picture to be taken and uploaded for someone with the reqiored knowledge to identify it.
May I suggest a simpler approach- The M series engines all have DOHC written on the top of the engine whilst the G series engines all have 16 valve written on top of theirs. Everyone will be able to find this and should therefore be able to identify their engine easily.
02 Feb 2018 21:44 #189056 by Johnniehec
Or
If you can see the plug leads and coil packs it's the earlier G13b with a cam belt. If you can't see them, they're under the plastic cover it's the later M13a with a timing chain.
02 Feb 2018 22:45 #189059 by Busta
Replied by Busta on topic Easy engine identification.
My point was that to simply read the words on top of the engine requires no prior knowledge.
  • Daniel30
04 Feb 2018 12:23 #189083 by Daniel30
Replied by Daniel30 on topic Easy engine identification.
Good for the wiki section
  • gilburton
04 Feb 2018 15:03 #189086 by gilburton
Replied by gilburton on topic Easy engine identification.
VVT??:laugh: :laugh: :laugh:
15 Jan 2021 15:35 #231838 by rich01
Replied by rich01 on topic Easy engine identification.
hi guys my jimny has the black cover over the plugs which has DHOC 16valve underneath , i’m wondering will this be
the G series engine or the M series cheers
Time to create page: 0.170 seconds
