No 4wd drive and flashing 4wd light
16 Dec 2017 15:55 #187541
by facade
Replied by facade on topic No 4wd drive and flashing 4wd light
Reads to me as if the transfer is going into 4wd, and the air hubs don't work (or more precisely, the vacuum switch in the engage line is not operating, because there isn't any vacuum, or the switch is faulty). If you quickly turn it off before it winds back into 2wd, when you turn the ignition back on it remembers it was in 4wd and doesn't check the vacuum switch as it isn't engaging anything so the light is steady.
Try shorting out the vacuum switch wires and see if the 4wd low will engage properly with the buttons.
- marcusleighus
- Visitor
16 Dec 2017 16:00 #187542
by marcusleighus
Replied by marcusleighus on topic No 4wd drive and flashing 4wd light
It isn’t actually going into 4wd at all
16 Dec 2017 17:44 #187545
by facade
You sure? 4wd might be engaged, but the hubs are not locked. Both things have to happen before there is drive to the front wheels.
How it works, bear with me...
In the Olden Days, when people did everything with big levers, and the strength of their arms, suzuki used fixed front hubs and a lever on the transfer box to first lock a dog clutch so the front axle was driven, and then go around a gate (or use a second lever, I'm not sure) to operate a second selector and engage low gears.
Then someone had the bright idea to fit unlockable hubs on the front, that you had to get out (on the mud usually) and lock so the front axle would drive. This is the system retrofitted to many jimnys as there isn't much to go wrong.
For the jimny, suzuki went for vacuum operated locking/unlocking hubs.
So inside you pull a lever, which moves the sleeve over the dog teeth of the front shaft (or doesn't, so you fiddle and move the car slightly until everything lines up and try again, it always will at walking pace) When the selector has moved far enough, the 4wd switch activates. This sends a signal to the hub controller, which activates the vacuum valves to lock the hubs. It waits a few seconds to see if there is a vacuum in the pipe, and if there is, it assumes that the hubs worked, and activates the 4wd light. If there is no vacuum in the pipe the vacuum switch doesn't operate, and it assumes the hubs aren't locked, and flashes the 4wd light.
Yours has a servo motor on the transfer box that does the job of the lever.
So when you press the 4wd button, a second controller first checks that the motor is at rest in the 2wd position (limit switch) and then motors it to the 4wd position (4wd switch activates) and switches it off. The 4wd switch then activates the hubs and 4wd light like the original jimny.
shifting into 4wd low, you need to stop and press the clutch (or select neutral in an auto). The controller first checks that the 'box is actually in 4wd high, and then turns the motor on again until the 4wd low switch operates. There is a spring between the low range selector and the motor, as if the teeth don't line up, it wont go in, it will go in as soon as something starts to move though.
The hubs are already locked so it shouldn't take any notice of the vacuum switch when going from high to low.
If it can't complete the shift within a set time, or any of the switches fail to match up with expectations, or you are moving too fast or too slow (speed sensor) , it aborts and goes back to the 2wd High position.
Now I think that your problem is the transfer box is going into 4wd high, so the front propshaft is driven, but the hubs don't lock, so the wheels won't drive. I'm not sure if having the 4wd light flashing in the first place will cause it to abort the 4wd altogether, or just ignore requests for 4wd low.
So as suggested above-
Put it in 4wd and jack up one front wheel with the handbrake on.
If the wheel will easily rotate by hand, the hubs are probably not locked. Crawl underneath and try to turn the front propshaft.
If it will turn, the transfer box is not in 4wd.
Shorting out the vacuum switch below the battery will cause the controller to think the hubs are working, and if the hubs are the problem, should allow selection of 4wd with a steady light, and then allow 4wd low to be selected.
If this fixes it then you simply fit manually controlled hubs and forget the vacuum system, like many others here.
16 Dec 2017 19:21 #187556
Replied by mlines on topic No 4wd drive and flashing 4wd light
Have a look at this (this is why I was asking the exact sequence)
- marcusleighus
- Visitor
16 Dec 2017 20:22 #187558
by marcusleighus
So going off that chart it would be that the malfunction is in the transfer shift actuator limit shift, where abouts would I locate it and would there be any obvious reasons to the malfunction when I do find it? Thanks for the suggestion facade I’ll give that a go
16 Dec 2017 22:10 #187560
The limit switch is inside the actuator mechanism, inside the transfer box. Therefore the bad news is that if it has failed then it is a new actuator module that is needed.
Attached is the diagram. As you can see it is in the wires to the transfer box with "YELLOW" as the main colour.
Your best hope is that the cable has been disturbed in some way and can be cleaned and re-seated. If not then the actuator has to come out and be bench tested. However actuator failure is fairly common,
Time to create page: 0.153 seconds
