No 4wd drive and flashing 4wd light
- marcusleighus
- Visitor
17 Dec 2017 15:57 #187576
by marcusleighus
Replied by marcusleighus on topic No 4wd drive and flashing 4wd light
I was driving this morning with the ECU unplugged all of a sudden the 4wd engaged, i plugged in the ECU and the flashing 4wd light was stationary and when I pressed 2wd it went straight back in with no issues whatsoever???
17 Dec 2017 16:15 #187577
Replied by mlines on topic Re:No 4wd drive and flashing 4wd light
That's a common problem as well, the actuator gets out of sync with where the controller thinks it is. Sound like you have effectivity reset it although the more common way is to wind the actuator back to 2wd
Sent from my Nexus 6P using Tapatalk
- marcusleighus
- Visitor
17 Dec 2017 16:17 #187578
by marcusleighus
Replied by marcusleighus on topic Re:No 4wd drive and flashing 4wd light
Do you think a missing hub nut potentially have anything to do with 4wd problems? I noticed one was missing when removing them
17 Dec 2017 17:03 #187579
You mean the large hub nut or do you mean the bolts that hold the vacuum hub in place. Either way it would have trouble holding vacuum
- marcusleighus
- Visitor
17 Dec 2017 17:22 #187580
by marcusleighus
The bolts that hold the vacuum hub in place there’s 5 out of the 6.. so that could be a possible cause??
17 Dec 2017 17:29 #187581
It would not have given the flashing message about the actuator sensor switches
Time to create page: 0.139 seconds
