Suspension Spacers vs 2" Procomp Kit
- 1066Boy
09 Aug 2017 19:01 #183294
by 1066Boy
Replied by 1066Boy on topic Suspension Spacers vs 2" Procomp Kit
215/75/15 will fit on a standard jimny so with the spacers I would of thought you will be ok unless you flex the rear to the max.
- Venter
09 Aug 2017 20:50 #183299
by Venter
Replied by Venter on topic Suspension Spacers vs 2" Procomp Kit
Also running 215/75/15 (Hankook Dynapro MT, not remoulds). Got a 2" spacer lift (or was it 1.5"?) and the tyres aren't even close to rubbing, reckon I could even get some 235/75/15's in there with no worries (anti-roll bar still attached).
Mine is a 2009, so it's the one with the bumper that gives the least clearance. My previous Jimny was a 2003 and had no problem with the 215's even with zero suspension lift. Wheels are 15x7, so not significantly different to your 15x7.5's
09 Aug 2017 21:00 #183300
by furo
Replied by furo on topic Suspension Spacers vs 2" Procomp Kit
Awesome, thank you very much. What are the Hankook MTs like on-road? And especially in the wet?
By the way I'm originally from Aberdeenshire too.
- Venter
09 Aug 2017 21:29 #183303
by Venter
Not bad at all on-road, although this is relative as it's still a MT tyre. If you aren't going to be speding much time off-road then go for something else, but if you want a MT then it's one of the best. They've got a fairly soft and tacky rubber (low durometer rating), which means they wear quickly when under a bigger 4x4, but with how light a Jimny is this isn't a problem. The tackyness does mean they grip really well in the dry though. They've got bout 40k miles on them and still have another 10-20k left.
In the wet, they're just alright, good as far as MTs go, but still far from good. I have adjusted how I drive and now have no problems any more, although there were a few arse-clenching moments when I first got them.
I'm in Insch, near Inverurie. Minimum temp tonight is 4 degrees, and it's early August! Bet you're happy to have left
Time to create page: 0.298 seconds
