Re:Re:Grand vitara calipers and discs
- Nissan300
- Visitor
03 Jun 2017 18:20 #181728
by Nissan300
Grand vitara calipers and discs was created by Nissan300
Hi guys I know no vitara calipers and disc are a direct replacement anbd upgrade to the jimny solid front discs my question is will grand vitara discs and calipers also bolt straight on ?.
Sent from my SM-G935F using Tapatalk
03 Jun 2017 19:30 #181731
by Keithy
Replied by Keithy on topic Grand vitara calipers and discs
I have vitara calipers and jimny vented discs fitted....fitted straight in....I remember bleeding was a modified approach as the nipple was lower....but they fitted straight on.
- Nissan300
- Visitor
04 Jun 2017 07:18 #181738
by Nissan300
Replied by Nissan300 on topic Re:Grand vitara calipers and discs
So just to confirm your calipers came off a grand vitara 98 on not the early vitara ?.
04 Jun 2017 07:59 #181742
by Keithy
Replied by Keithy on topic Re:Grand vitara calipers and discs
I think mine are the early vitara.....caliper itself is the same as grand vitara....not measured the carriers though. mdb1690 pads
- Nissan300
- Visitor
04 Jun 2017 13:30 #181755
by Nissan300
Thanks Keithy it's been hard trying to find early vitara calipers that had vented discs and a 5 door for bigger pistons.
06 Jun 2017 07:24 #181780
Replied by yakuza on topic Re:Grand vitara calipers and discs
These calipers are readily available new, and not so costly either if you buy them online.
I strongly recommend to buy spanking new brake parts mainly for two reasons:
Availability. If we don't buy new service parts they will be more expencive due to lesser volume made and in the worst case discontinued.
Safety. I sell alot of used car parts but never sell used brake parts or other safety related parts like seat belts..
You never know what the donor vehicle has been thru.
Early Vitara lwb 5 door 1.6 16v calipers from around beginning to 1998 will fit.
Note that 3 door and 8 valve models does not have vented discs.
Bleed port will not face upwards so you will need to loosen calipers and turn so the bleed vent is up when you bleed the brakes as Keithy mentioned .
Early Vitara vented discs has smaller inner diameter in the center hole on the brake disc so these did not fit my 2005 Jimny.
But Jimny Diesel discs is the thing i guess?
Time to create page: 0.162 seconds
