headlining removal
  • philpridd
29 Jan 2017 09:38 #177461 by philpridd
headlining removal was created by philpridd
hello all,I would like to fit a permanent cb aerial mount to the roof of my 2008 Jimny,anyone know how to remove the headlining? Thanks,Phil.
29 Jan 2017 09:48 #177462 by jackonlyjack
Replied by jackonlyjack on topic headlining removal
hi the lining will have a small amount of glue running down the centre in a wavy line
so be patient when pulling it down ;)
Jack
  • philpridd
29 Jan 2017 10:31 #177463 by philpridd
Replied by philpridd on topic headlining removal
thanks Jack,will get to it sometime this week.
29 Jan 2017 11:13 #177465 by facade
Replied by facade on topic headlining removal
If you are gluing it back, you must use a high temperature/heat proof adhesive, or it will drop down as soon as the sun shines on the roof. :pinch:
The following user(s) said Thank You: philpridd
29 Jan 2017 11:14 #177466 by Keithy
Replied by Keithy on topic headlining removal
jackonlyjack wrote: hi the lining will have a small amount of glue running down the centre in a wavy line
Jack
Be a little more patient than we were taking it down from the Black-Jack Jimny? :D
It at least gave me a peep at how mine is held on matey! :beer:
Removing the roof lining and refitting without creasing it.....has to be trickier than a full gearbox strip and rebuild!
Whereabouts is the aerial to be situated Phil?
  • philpridd
29 Jan 2017 11:38 #177471 by philpridd
thanks again Jack,l really want the aerial in the centre of the roof,it came with a magnetic mount,but I would prefer a permanent mount,with a quick release fitting,so I can just remove the aerial,without disturbing the lead to the c.b.,though if its too much of a job,I may stay with the magnetic mount,Thanks Phil.
Time to create page: 0.131 seconds
