Jimny Cat Inards removal.
  • Paul0283
05 Jan 2017 22:19 #176288 by Paul0283
Jimny Cat Inards removal. was created by Paul0283
Hi all,
Apologies if this topic has been already covered. I have a 2012 Jimny, which I've owned for about 7months. Recently, it's developed a rattle from the forward Cat. I'd considered ordering a new Cat to replace it, until I read a few posts regarding Cat removal. Can anyone tell me if I can remove the inards from the front Cat without adversely affecting the car please? I've seen various references to fault lights coming on with no Cat fitted. It'd be really handy if, besides sorting the rattly Cat, I gained a little more oomph in the process. Also, can anyone tell me if removal of the front Cat inards renders the car an MOT failure please? Thanks in advance.
06 Jan 2017 07:51 #176296 by skywalker65
Took the exhaust manifold cat out on my 06 model as it was breaking up. I've still kept the other cat further down the system. No probes re mot emission test or EML issues. No real difference in performance.
Regarding MOT. If you have a standard looking exhaust system and it passes the emissions test then I don't think they'd be that bothered. They won't take your exhaust system apart just to see if there's a convertor installed
If in doubt ...... Flat out ??
The following user(s) said Thank You: Paul0283
06 Jan 2017 15:18 #176312 by mlines
Replied by mlines on topic Jimny Cat Inards removal.
rather than the CAT failing I would check if the CAT heat shield is broken. This usually corrodes through on one of the spot welds and then buzzes and rattles.
  • Paul0283
06 Jan 2017 16:03 #176315 by Paul0283
Replied by Paul0283 on topic Jimny Cat Inards removal.
I'll check that as soon as the rain stops. Cheers
  • Paul0283
06 Jan 2017 16:05 #176316 by Paul0283
I'll check the Cat heat shield, as suggested by mlines below, before I delve any deeper. Thanks
06 Jan 2017 17:27 #176324 by Busta
Replied by Busta on topic Jimny Cat Inards removal.
I doubt the original CAT has failed after just 5 years. I believe Suzuki employed a team of crack engineers to design them to fail at a similar time to the crank pulley and the crank position sensor, which is 80,000 miles or 12 years.
