Steering wheel change
- Seantdi
13 Jul 2016 22:53 #170012
by Seantdi
Steering wheel change was created by Seantdi
New here guys. Picked up a 2002 jimny at the weekend.
One problem I have is that the steering wheel is starting to come apart. Well the material is flaking off and is gone loose on the steel inner part..
Can these be replaced with a wheel from a different model suzuki or will only a jimny one fit?
14 Jul 2016 08:09 #170020
by kirkynut
Replied by kirkynut on topic Steering wheel change
There was a post on this a few months ago. Have a search. The airbag is the issue rather than the splines on the shaft.
The following user(s) said Thank You: Seantdi
- gusthegorilla
14 Jul 2016 10:15 #170040
by gusthegorilla
Replied by gusthegorilla on topic Steering wheel change
Agreed...but if you can find a steering wheel off a Jimny 'Mode', they're slightly better in appearance and quality, and would solve the airbag issue.
Gus
Gus
- Talkstar
31 Jul 2020 22:00 - 31 Jul 2020 22:02 #225917
by Talkstar
Replied by Talkstar on topic Steering wheel change
I changed my Steering wheel yesterday.
Went super fine. From a 3 spoke 2006 - 2014 JB43 model in leather to a 3 spoke 2008 - 2012 Swift ZD11S in leather with Audio controls on the wheel.
Required a bit of a fiddle but nothing impossible.
Pics attached
Quite satisfied. Wheel fits almost "straight out of the box". To get the Audio controls to work took a bit of thinking, but eventually I solved it relatively simple. My aftermarket stereo has learning function for different OEM solutions. Swift uses, like most Japanese, an variable electrical resistance to control all the functions.
Pics attached
Last edit: 31 Jul 2020 22:02 by Talkstar. Reason: Typo, info missing
- Max Headroom
- Banned
- Thank you received: 216
02 Aug 2020 09:39 #225974
by Max Headroom
Replied by Max Headroom on topic Steering wheel change
This could be a good 'How to' article to go into the Wiki if you made a step-by-step guide
- Talkstar
03 Aug 2020 20:50 #226051
by Talkstar
Yes, great idea. I took some photos of the operation so I will write an small 'how to' guide.
Thanks.
Thanks.
Time to create page: 0.108 seconds
