Galvanised Chassis
  • dmonk
27 Jun 2016 07:08 #169194 by dmonk
Galvanised Chassis was created by dmonk
Hi All,
Anyone know where I can get a galvanised chassis for a T plate Jimny? Seems like the salt has got to it.......
Cheers,
Dave
27 Jun 2016 09:02 #169197 by Busta
Replied by Busta on topic Galvanised Chassis
Nobody stocks them. Your only option would be finding a good chassis and getting it galvanised yourself. But it would be cheaper to cut your losses and buy another Jimny that wasn't rotten. If the chassis has rotted, the body won't be far behind and you can't galvanise that!
27 Jun 2016 09:15 #169199 by kirkynut
Replied by kirkynut on topic Galvanised Chassis
I'm surprised that the chassis has rotted ahead of the body as Suzuki chassis are quite good but the body shells are not.
As has been said, getting a good used one would be the answer but I wouldn't go to the time and expense of galvanising it as it will out last the rest of the car making it uneconomical if you are prepared to scrap it later due to body rot.
You will run into vehicle identification issues though. As long as you grind off the old chassis number and stamp it with your original one I don't see the issue as you are changing it like for like - just as Landrover folk do with new chassis and there's nothing dishonest about it if the donor car is not stolen.
27 Jun 2016 17:54 #169211 by Rhinoman
Replied by Rhinoman on topic Galvanised Chassis
kirkynut wrote: You will run into vehicle identification issues though. As long as you grind off the old chassis number and stamp it with your original one I don't see the issue as you are changing it like for like - just as Landrover folk do with new chassis and there's nothing dishonest about it if the donor car is not stolen.
I don't believe that is legal, as I understand it its illegal to alter the chassis number therefore you should stamp the new number next to the old one; the law is intended to ensure that the replacement chassis is traceable. A new replacement chassis is different because it will be provided without a number.
27 Jun 2016 18:17 #169217 by Jezz
Replied by Jezz on topic Galvanised Chassis
My understanding is, (and i'm happy to be proved wrong). The registration and number plate stay with the chassis, not the body.
To grind off a chassis number and re-stamp it, Is creating a ringer.
It's been fettled just a tad.
27 Jun 2016 20:10 - 27 Jun 2016 20:12 #169222 by Rhinoman
Jezz wrote: My understanding is, (and i'm happy to be proved wrong). The registration and number plate stay with the chassis, not the body.
A chassis swap alone won't give enough points to retain the number plate from the vehicle that donated the chassis. Technically its not a chassis number but a Vehicle Identification Number (VIN) so it stays with the vehicle.
Last edit: 27 Jun 2016 20:12 by Rhinoman. Reason: clarification
Time to create page: 0.108 seconds
