three wheels on my wagon
- darthloachie
17 Nov 2010 12:25 - 17 Nov 2010 12:28 #6026
by darthloachie
three wheels on my wagon was created by darthloachie
broke the front axle
offside halfshaft is snapped, axle was full of muddy water, kingpin and wheel bearings are shot, the freewheeling hub bolts are sheared off in the hub covers
Ordered the bearings and seals off Martin
Anyone got a half shaft or the hub covers?
Last edit: 17 Nov 2010 12:28 by darthloachie.
- darthloachie
18 Nov 2010 12:31 #6085
by darthloachie
Replied by darthloachie on topic Re: three wheels on my wagon
I've got the half shaft and hubs coming from Rob at O.R.A. on Monday
- gazert
24 Nov 2010 18:18 #6423
by gazert
Replied by gazert on topic Re: three wheels on my wagon
Ow are u getting on?
Since my bath at tick hill my hubs died and now the king pin bearings have died!
Busy weekend for me.
- darthloachie
24 Nov 2010 19:22 #6432
by darthloachie
When the garage took the half shaft out and out poured muddy water.
The short half shaft (drivers side) had snapped and both hubs were shot
one of the wheel bearings was knackered together with all the kingpin bearings
Now got all the bits
half shaft and 2 hubs from Rob at ORA (CamSuzuki had none) and two sets of king pin bearings and a wheel bearing from Martin
Oh and a wading kit for the axle breathers - (better late than never)
£250 so far
The garage are going to strip the axle and clean all the inside out and rebuild it with all the new / second hand bits
Hopefully it will be done by next Friday so we can go to tong - problem is it will only fit on the lift they use for MOTs so has to be fitted in between MOT bookings
Good job its not my daily driver!
£250 so far
24 Nov 2010 19:38 #6437
by kirkynut
Replied by kirkynut on topic Re: three wheels on my wagon
Crickey, what did you do to break the shaft?
You have a reasonably large and aggressive set of tyres and a rocklobster don't you? Remind me what you run?
I bet you were having fun till the shaft went though!
I wonder if KAM diffs have sorted their hardened front shafts and cvs yet?
You'll have to learn to fix it yourself and you'll save a fortune but as Martin has found, become a pest to local garages with a press!
I'm lucky to have a step father in law with a press I can use whenever for wheel bearings and bushes.
- darthloachie
25 Nov 2010 12:29 - 25 Nov 2010 12:37 #6464
by darthloachie
yep 31" Insa Turbo Special Tracks and an ARB front locker
was stuggling to get up a hill we had shot up 10 mins earlier - engauged the ARB and shot off sideways - wife was screaming as we were half way up a steep hill :S got to the top eventually - would still eat small steep climbs but struggled with longer ones without using the ARB to get three wheel drive
looked on Kam's web site t'other day when looking for parts and they only qoute rear hardened - my son found a picture on Chris's facebook (who had the car before us) of about 8 broken half shafts! but then he drove a lot more aggressively than we do
I can do simpler repairs but axles are beyond me :blush:
Have you fitted your rear disk brakes yet?
Last edit: 25 Nov 2010 12:37 by darthloachie.
Time to create page: 0.232 seconds
